Regional : Asia Pacific : about Smart Communications' MMS (PH)
< Esato Forum Index > Regional > Asia Pacific > about Smart Communications' MMS (PH) Bookmark topic
Page <  12
maestro_musica Posts: 27
For your MMS activation:
Type SET(space)MMS(space)ET68i then send it to 211.
*just copy the format with all letters capital except the "i" in the ET68i. By the way, this only applies to SonyEricsson T68i handset so ask *888 for the code of your handset. After a few minutes, or seconds maybe, you will receive an OTA(over the air) settings of the MMS, just clicked Install and it will automatically install that to your phone.
For your GPRS activation:
Type SET(space)GPRS(space)ET68i then send it again to 211
*you will again receive an over the air settings and do what you have done in setting up your mms
Upon receiving the settings, you will receive a text message from smart. Do what it says and smart will do the rest. That's all. By the way, since you bought this phone not directly to smart or globe, go to the Menu Connect. Then to Data Comm. Then Data Accounts. After going there, you will find many setting (GPRS and MMS as well as CSD) there. Erase everything living only the settings SmartMMS and SmartGPRS. You can see these settings after you installed the OTA settings I have told you to do so. I think, that will solve your problem
Posted: 2002-12-21 02:53:00
kaishakunin,
call *888 regarding your problem and they will aid you with that. Sometimes, when we don't use MMS, they deactivate it. I supposed. After 10-15 days that you didn't use that service even the GPRS one, they deactivate it. Globe is currently doing that, i don't know in Smart.
Regarding animations, I do not know how to build an animation there in SE T68i. I supposed you cannot so such thing. If you are looking for animation, just go to the Esato wapsite and select screen saver. Or you can simply go to the Smart Wapsite and there they offer many animations that costs 15 per download. Or you can also visit, wap.phoneimage.com and there, you can find many animations offered for free.
Posted: 2002-12-21 03:00:00
littlestar Posts: 1
I am a globe prepaid subscriber and i also have a smart prepaid sim. I tried to activate my MMS and GPRS ng smart sim ko throuh OTA. Ok ayos na bt wen i try 2 view yng mga mms ko na d ko mbuksan ayaw pa rin.May prob daw s network.May charge b GPRS ng smart?Kainis kala ko p nman magagmit ko na yng mms na feature ko. :( This post was posted from a T68i
Posted: 2002-12-21 09:33:00
littlestar Posts: 1
Posted: 2002-12-21 09:34:00
littlestar Posts: 1
Posted: 2002-12-21 09:35:00
Ok ganito iyon. Same yung experience mo sa akin. Nai-ON mo na ba yung GPRS and MMS mo at naiset mong mabuti yung server ng MMS mo sa Smart? Kase minsan pag nagpalit tayo ng Sim card, kahit iba na yung account, naiiwan pa din yung server nung dati mong network. Try to check it. Ang dapat message server ng MMS mo e http://10.102.61.238:8002. Iyan dapat ang maging server mo. Then kung ayos na ang lahat, wag ka munang sumuko dahil ang activation ng MMS at GPRS will take 24-48 hours. So try to check it after such then post ka dito kung ano na ang nangyari.
Posted: 2002-12-21 10:21:00
littlestar Posts: 1
Well, naka-ON na silang pareho. May bayad ba GPRS ng smart? Parang lakas ata naubos nung load ko nung nag-connect ako o imagination ko lang yon. Sige try ko bukas kse i dont have my sim here and i will let u know kung gumana na. tnx in advance!
Posted: 2002-12-21 18:55:00
Well, the sad thing is merong credit na binabawas ang smart for every KB received and sent so talagang nababawasan yung load mo. Kasi ang maganda naman sa Globe they are giving this service free of charge yun nga lang, makikipagbabag ka muna sa mga tanga nilang attendant bago pa man ma-activate yung GPRS as well as the MMS feature of your phone. Sa Smart, walang ganoon dahil basta meron kang load, you can avail everything. Wala ng usap-usap na kailangang gawin.
Posted: 2002-12-22 04:51:00
ynohtna Posts: 278
Since we are in the smart thread,might as well add this:Entertainment section phil star jan05 this year,smart will be launching their own SMART AMAZING PHONE!from the pix,it is not a nokia,moto,se,siem,samsung nor philips.It has a mp3 player,digital camera and the os is by microsoft.The only brand i know with a microsoft mobile explorer is the SENDO smart phone z100(i think if i am not mistaken). Any opinion? This message was posted from a T68i
Posted: 2003-01-13 02:11:00
geussepe53 Posts: 70
Hi maestro this is geussepe again,regarding the MMS message, Do you rememeber last time that you have send an MMs message to me onmy Smart number the 091202284405 and you are using globe i have not receive it from the MMs message menu, so i decided that shifting from smart to globe now my mobile number is 09167057649! Sorry i have not able to retrieve your number, pls send me your number on that globe number, because i have reset my phone and i was not able tos end my contact numbers on my simcard, pls give me your number Im so bored of having no text mate in my mMs message! Pls try to send me once again a n Mms message on the smart number because until now my globe number, the GPRS is not activated but i configured it naman a week ago pa, can you help me about this matter?
Posted: 2003-01-18 08:09:00
Page <  12
