Sony Ericsson / Sony : Symbian phones : Has the satio touchscreen improved?
< Esato Forum Index > Sony Ericsson / Sony > Symbian phones > Has the satio touchscreen improved? Bookmark topic
Page <  12
etaab Posts: > 500
I think thats nonesense. My Satio hasnt a scratch on it and ive hard it 6 months now and i took the plastic cover off the day i bought it.
It depends how well you look after your posessions. I do, therefore no scratches. In regards to the touch screen sensitivity, mine is fine. It misses a few taps at times but then its not of the same technology as the more sensitive iPhone.
Personally i dont think any touchscreen can be as responsive as using mechanical buttons - no ?
Posted: 2010-04-22 19:51:27
Rakan Posts: 17
Remove it or No ??
Posted: 2010-04-22 20:07:50
etaab Posts: > 500
Remove it. Then just take care of the phone.
If you leave it on it will make the screen less responsive and images look worse.
Posted: 2010-04-22 20:33:30
Rakan Posts: 17
0k, i'll remove it & use pouch phone
What do you think ???
Posted: 2010-04-22 21:01:14
etaab Posts: > 500
Thats what i do. I have a very old thin neoprene pouch with a fake suede outer. Wouldnt protect the phone from hard knocks but stops scratches.
Posted: 2010-04-23 00:46:04
Rakan Posts: 17
Thank you very much
will do it
Posted: 2010-04-23 01:07:37
Rookwise Posts: > 500
Take the factory protector off and buy an Expert Shield screen protector (www.expertshield.com) and also buy a pouch or a hard leather case for complete protection.
Krusell leather pouch's are very good. I've got a red one which I use with my red Satio. Cost about £12 GBP.
[ This Message was edited by: Rookwise on 2010-04-23 00:15 ]
Posted: 2010-04-23 01:14:20
Page <  12
