@tapas123
Those specs are just rumors but if they are true the S4 will need a 4000mAh battery. The Nexus 10 tables uses the dual core version of the Exynos 5 and its battery life is much lower than other comparable tablets.
Even before the S3 came out rumors were stating that it will have much batter specs than the final product had.
Posted: 2012-11-20 20:54:42
On 2012-11-20 20:23:32, king-james wrote:
Sony Yuga and Odin dimensions leak: 5-inchers more compact than the Droid DNA
http://www.phonearena.com/new[....]act-than-the-Droid-DNA_id36836
I like the headline.
S3, Note 2 and YUGA Comparison:
S3 4,8": 136.6 x 70.6 x 8.6 mm
YUGA 5": 138.6 x 71 x 8.1 mm
Note2 5,5": 151.1 x 80.5 x 9.4 mm
I expect S4 with 5" will be at least 140x73x9 mm (something between S3 and N2)
Notice: YUGA will be easier to use than S3. Thanks to the on-screen-buttons and similar size...
I also think SONYs 6" Phablet won't be bigger than N2.
[ This Message was edited by: king-james on 2012-11-20 19:35 ]
Well, that info is one page back...
Anyway, not much bigger than S3. Should fit on my hands.
Posted: 2012-11-20 20:56:51
Except maybe for the thickness of Odin, the other dimensions are really remarkable + the IR remote
. These rumours are an emotional rollercoaster, that's for sure
. First, there was Dogo with more than acceptable specs. Second, Yuga pics leaked and then there were new rumours that indicated even better hardware (mainly battery). And now this, it's almost impossible to be dead set on which to get of these phones
Sony C2104:
http://www.glbenchmark.com/ph[....]rall&benchmark=glpro25&var=top
Posted: 2012-11-20 23:15:12
Yuga all the way as far as I'm concerned. It looks amazing even in those spy shots
Posted: 2012-11-20 23:22:15
What if Yuga is only for Japan?
Posted: 2012-11-20 23:34:23
No DACHA...
Pls don't say it...
It'll break my dream...
Posted: 2012-11-20 23:39:07
There are rumors that Yuga will only be available from NTT docomo in Japan. Usually the phones that are exclusive to NTT docomo are not available globally.
[ This Message was edited by: DACHA on 2012-11-20 22:52 ]
Posted: 2012-11-20 23:50:57
DON'T SAY THAT! YOU ARE MAKING ME MORE INDECISE. I'm not sure anymore on what I want: IR Remote or Water/Dust proof. Well, I hope for the second.
Posted: 2012-11-21 00:04:45
@DACHA Already i'm pissed off at Sony's strange strategy... Now this... Why on earth do they keep same models with minor changes...??? Why can't they keep one solid device like other manufacturers do...??? Odin's a bit smaller than Yuga & has IR blaster whereas Yuga is slightly thinner & lighter than Odin & has waterproof... Above all, they're gonna confuse buyers by releasing them in different regions... I wish Sony came up with one solid device with the above scattered specs together...
Posted: 2012-11-21 00:16:05
But I thought IR was more of a Japanese feature. I'll go mad if Yuga is a Docomo handset only. I'd be surprised if the non IR Odin was heading to Japan.
[ This Message was edited by: goldenface on 2012-11-20 23:19 ]
Posted: 2012-11-21 00:17:17
