On 2013-06-13 14:49:29, randomuser wrote:
What is also interesting is HTC probably decided to fool everyone with the Ultrapixel crap. Htc One Pixel size comes to 1.79 microns only and not 2.0 microns
4400/2688 = 1.785
[ This Message was edited by: randomuser on 2013-06-13 13:50 ]
Apparently HTC does not lie, and actually i think what they did is smart. According to Anandtech, their sensor format is not 4:3 but 16:9. I could not find the dimensions, but starting from there, we can compute.
A 4:3 sensor of 1/3" would have dimensions of 4.8mm x 3.6 mm, so a diagonal of 6mm, this diagonal would correspond to the 1/3" format name for some reasons unclear to me.
The HTC sensor is 16:9, we know that it has a pixel pitch of 2 micron when used with a resolution of 2688 x 1520 pixels. Then the dimentions are about 5.376mm x 3.040mm which gives a diagonal of 6.176mm, so we fall back on the right dimension to fit 1/3" definition, so it does not seem like marketing outright lie.
So your equation should be: 5376/2688=2.
I actually wish Sony would do something similar, with a sensor form factor that is not 4:3, maybe 3:2, for the honami.
Posted: 2013-06-13 18:06:48
XperiaJunkie Posts: > 500
Any one who want to know what kind of touch screen the Togari will have it is an Optical touch panel with the tech coming from a company called Neonode. Sony have used their tech in the e-readers for some time now here is a link to a demo of how accurate the screen is to almost any kind of imput.
http://www.youtube.com/watch?v=31E-hFeY2RI
Posted: 2013-06-13 18:08:00
On 2013-06-13 17:33:43, sighduck wrote:
And I hope that hole on the right side is neither the audio jack nor the stylus hole.
If it was the audio jack, it'd be impossible to play music while it's in your pocket, it's an awkward place.
If it was for the stylus, it would be an awkward placement for left handed people like myself.
+1
It's not for stylus because it's so tiny and we know chance of stylus with togari is really low.
its audio jack and placed really bad.
Posted: 2013-06-13 18:12:24
On 2013-06-13 15:35:06, kurtdean wrote:
It's confirmed ip58
Guys look at the onscreen bar. It almost as black as the bezel
[ This Message was edited by: kurtdean on 2013-06-13 14:38 ]
Yup, it will be IP55/58, and not IP55/IP57 for Togari just as I stated before
Posted: 2013-06-13 18:16:23
The Battery of Togari has only 3000mAh not 3500... So this will kill Togari for sure...
You can't comapre it to a Note II. The Note has only 5,5" screen and only HD pentile matrix resolution + 100mAh more...
Togaris screen is 1" bigger + it has 1080p FullRGB resolution! Damn, you can recharge Togari 2x per day...
So I go with Honami. Togari will be a nice device, but battery will be the k.o. 4000mAh would be at least necessary or screen should be smaller or only HD resolution...
[ This Message was edited by: king-james on 2013-06-13 17:45 ]
Posted: 2013-06-13 18:38:50
Numbers alone don't mean anything. I'll wait till battery life reports get in.
Posted: 2013-06-13 18:47:53
Shut up... or SAS will kick your ass out loud.
Actually they already kicked it two times already!
Posted: 2013-06-13 18:57:08
Relax, it's just my opinion dude... MIA will destroy SAS tonight!!!
[ This Message was edited by: king-james on 2013-06-13 18:01 ]
Posted: 2013-06-13 18:59:44
We shall see
Posted: 2013-06-13 19:22:01
You would think so. but unless sony figured out a way to implement this type of optical touch without using a border to house the IR leds, it's unlikely.
considering the leaked pics show togari sensing pencil input through a piece of paper, it doesn't seem that IR touch is how it works. based on my understanding, the paper would have interfered with the IR field over the surface of the screen, making any accurate input detection with the pencil impossible let alone as accurate as shown.
Posted: 2013-06-13 19:32:50
