Agreed Aurelius, courtesy is important, i hope the moderators understand that if they hope to create a community of sony xperia enthusiasts rather than rebuke new members.
If one does not like one post, one would better just ignore it. Most probably have posted off topic in the past anyway, so no one is in position to criticise others. Besides, complaining about off topic posts is kind of a nonsense as it is itself an off topic post.
Posted: 2013-06-16 17:08:48
Honami sounds to me like all features on it will be stand out - the best of Sony, so I would expect it to be packed with camera centric features and I hope Xenon and an active lens cover are just a couple of them.
I loved the Active lens cover on the C905, it was quick and very easy to boot the camera up.
Posted: 2013-06-16 17:27:30
i wonder how will the waterproofing be if there is a lens cover
Posted: 2013-06-16 17:33:28
I think it will not be a problem. SE S003 is water resistant with sliding lens cover
Posted: 2013-06-16 17:43:50
@goldie
This will make the phone thickens up too 12-13mm,so 5 inch with this thickness will make phone no sense,so the only solution would be less thin in flash department or some new generation flash integrated in the phone.and also rumours says flat back,so where does the flash comes,i guess if we go across rumours,there may not be having any flash,it contradicts in this case.
probably bigger sensor with powerful led?any comments?
Posted: 2013-06-16 17:47:37
all these guys worrying about a few mm in thickness.. do you all wear skinny jeans or somethin?
i know my pockets have plenty of room.
Posted: 2013-06-16 17:54:50
bro we are discussing pros and cons,but to answer you,its not matter of phone keeping in your pocket.fuure phone are thin phones not the fatty phones,people want phone up to 6mm irrespective of size(5inch to 12 inch),so in this case,if there is word xenon flash obviously the phone will be thick,which will not be good show from part of the sony showcasing One Sony High end phone.so probably this also hints us there will be same two smartphones with very thing and thick camera centric phones
[ This Message was edited by: vikeviki on 2013-06-16 17:00 ]
Posted: 2013-06-16 17:59:45
I am happy with a thicker phone, even 5 inch, if it means no compromise in the camera department.
But i know people that would not buy it simply because they have smaller hands!
But isn't it supposed to be a smaller footprint model that would be positionned as the iphone competitor?
Could it have a lower camera spec, and hence not the flagship "best of sony", but just beat the iphone at everything the iphone does? Isn't it compatible?
Posted: 2013-06-16 18:04:00
Then there is no point in having this extravagant rumour
Posted: 2013-06-16 18:08:55
I don't mind about the Honami being, what some believe, supposedly ''thick'' by today's ''modern'' standards. By any means, it will be thinner than my Sony Ericsson Xperia X10 mini pro, which my [soon to be] Honami will replace. It will be a huge jump technology-wise from my X10MP to the Honami!
Posted: 2013-06-16 18:23:20
