Page <  123 ... 104810491050 ... 184118421843>
Away Posts: > 500
@maiaramdan
Glad you're back. And that too with good news. Maybe I should become a patent troll and patent the wedge shape. If anyone decides to use it, I and Swiss cheese producers will sue them like no tomorrow! Apparently, Swiss cheese producers abuse the patent system more than Apple farmers!
If it's the omnibalance design but thicker, will it look very similar to the Z? Or is omnibalance a more general term to the extent that honami will look significantly different?
Posted: 2013-06-16 20:58:37
Ambivalent_ Posts: > 500
On 2013-06-16 20:12:31, maiaramdan wrote:
On 2013-06-16 19:57:00, HxH wrote:
On 2013-06-16 19:32:45, Rockarel wrote:
I find it hard to believe that Sony would go from their previous design philosophy of "Omni-balance" to a wedge shaped design in one generation of phone. I'm still hoping that they make a phone with a curved back similar to the HTC one. More room, good ergonomics, no EOS hump.
should I say that Sony already done with slightly curve back with Xperia S / P and ion in 2012, then Taiwanese which already run out of innovation copy it for fame design, Hell yeah! Those praises is much better serve for Sony instead!
Don't worry all, it will be the same beautiful omni balance, and not more that 1 cm
Hi Maia!
Could you please share some info on Honami, for instance can you confirm Xenon with 99% certainty.
Posted: 2013-06-16 21:42:48
maiaramdan Posts: 308
On 2013-06-16 20:58:37, Away wrote:
@maiaramdan
Hi Maia!
All info I had now is relating to the design, which will be as I said before in the past while Sony was thinking not to drop the ZL with the Z and postponed it
It seems that the Honami aka Z2 will be so much like the ZL from the front with the low bezel with some NXT touchs just as I said in January
Carbon-fiber in corners and side with internal metal panels and back large camera at the middle with metal under the remain of the camera and carbon fiber from the top, another thing the front camera will be at the top not as the ZL
Posted: 2013-06-16 22:23:49
Thanx man, please keep us up to date as you learn more info.
Posted: 2013-06-16 22:31:49
sami92a Posts: 423
i´m trying to make a picture of it in my head, will the metal be under the lens where the battery goes and everything and Carbon fibre over the lens on the top part of the phone?
Posted: 2013-06-16 22:39:26
Imagine a big circle in the middle that takes approximately all width all the top of this circle is carbon fiber finish as the sports car and all the bottom in metal
At the bottom imagine the shape of the small Mic on the Z but it is tall and around this a tiny NXT line and same from the top
Posted: 2013-06-16 22:45:58
MNX1024 Posts: 413
May you just give us a crude drawing.
Posted: 2013-06-16 22:52:58
sami92a Posts: 423
hmm i THINK i get it now.. but can you as MNX mentioned maybe give us an drawing to make us understand a little better
Posted: 2013-06-16 22:59:37
I've got some sort of idea. I'm liking what I hear.
Posted: 2013-06-16 23:09:19
Maia, how are you at MS Paint?
Posted: 2013-06-16 23:13:53
