I saw the videos posted about the plasma light and it's so much brighter and consumes less power! If Sony really incorporated this technology into this phone I will be very happy because I believe in their ability to create new technology advancements. That flash seems to even overpower xenon and the colors made the whole room more natural day color!!! That's what evens photographer wants in a flash!!! Natural looking flash compensation colors!
just hope this rumor is true! And if they successfully made it happen, hope other companies don't copy it. It will mean that sony has created another 1st!
Sony . Make. Believe
[ This Message was edited by: tai020381 on 2013-06-21 04:02 ]
Posted: 2013-06-21 01:07:18
@goldenface In the browser (chrome and most others) double tap is the one finger solution to zoom to a specific part of the page. In Google Maps double tap with a slide up or down is the preferred one finger zoom method. Long press is usually used for context menus in dynamic content apps on more recent android versions so is unlikely to be brought back as a zoom method.
Posted: 2013-06-21 01:12:31
On 2013-06-20 21:03:29, Away wrote:
We shouldn't be so harsh. Hate the trollish comments, not the (potential) troll.
Anyway, on topic, are there any rugged phones like the successor to the active and go scheduled?
Xperia ZR is the successor to active
Posted: 2013-06-21 05:16:28
Nope. Xperia Go is. Xperia ZR's predecessor is Xperia Acro S and Xperia V. Active's successor is Xperia Go.
Posted: 2013-06-21 05:54:52
@unknown
I meant in 2013 because they got same ip rating. 2012 is xperia go
[ This Message was edited by: kurtdean on 2013-06-21 05:05 ]
Posted: 2013-06-21 06:05:06
quick question, @randomuser @huiyi is there a microSD slot on Honami? if so then do you know which side is it placed? or is it not visible outside like xperia go, Thanks.
[ This Message was edited by: reeflotz on 2013-06-21 05:28 ]
Posted: 2013-06-21 06:27:09
On 2013-06-20 17:34:14, moogoo wrote:
@Shotokan81 - is than an IPHONE i see?
Blasphemer!!!
So, Honami isn't as camera centric as some of us would have liked it to be. No big deal. Having a xenon flash would have been nice, but apparently, we'll be getting a thinner device instead. That should make some people happy. With a bigger sensor and exmor-rs, low light photos should still be better than older phones. not to mention the new jpg algorithm. overall, we SHOULD see an improvement over older models and should be better than other flagship general purpose phones since honami will have a larger sensor.
it is interesting to me that it will have interchangeable lens design on a non-camera centric phone. almost seems gimmicky at that point. but either way, as much as i love photography, i wouldn't be one to invest in interchangeable lenses for my phone when i'd much rather invest in lenses for my dSLR.
There is a lot of slim devices from which we can choose, not just by Sony, but from other manufacturers as well. With Xenon flash Honami would show something new, otherwise in terms of usability, and functions what
real improvements could you name?
And without Xenon flash is nearly impossible to take a decent shot at a party for example, doesn't matter how improved the low light performance it is. And a party photo would be the perfect example also, where you don't want to carry a camera but you don't want to miss the moment either.
I think, and I hope that after four years break all important manufacturers will implement again Xenon flash in their camera centric (and not necessarily high-end) models. This time, without Xenon flash, Sony would be behind the competition again, in spite of Sony Ericsson was THE leader in this field in 2005-2006 with the K750, and K800.
Posted: 2013-06-21 07:14:36
@Reeflotz
Yes there is a microSD slot, I think on the right side.
Posted: 2013-06-21 07:28:35
Volume rocker,power button, camera shutter key and Micro SD slot on the right side???
They should put it inside...
Posted: 2013-06-21 07:47:30
huh... I hve used htc one extensively for low light shots & it does a superb job!!!
Just xenon isn't everything...
And if sony is behind d competition wid honami than no one is ahead either!!! Stop livin in d past...
Posted: 2013-06-21 07:57:37
