They have 3 months left according to rumors, how much of a prototype can it be!?
Posted: 2013-06-26 12:55:48
On 2013-06-26 12:55:11, razec wrote:
On 2013-06-26 12:51:37, unknownC151A wrote:
I actually have some photos of it. But I already promise I won't share it. But I will answer any descriptions.
Any visuals details about the camera that you can describe to us?
could you tell if it's really using G lens?
He refused to show the back. It's 20MP though. I can answer question about the front and side.
It's sliver/white on a black screen. Looks like a Z though.
Posted: 2013-06-26 12:57:15
Add on: SD card on the left flaps. Try to imagine a thicker, without the curve, Xperia v.
Posted: 2013-06-26 13:00:17
that's great! The Z has the best design ever! they don't need to change it! they can keep it and just do little changes with it!
Posted: 2013-06-26 13:00:28
Is the bezel visibly thicker than the Xperia Z?
Posted: 2013-06-26 13:03:04
The Z was a bit wide I think, so 2mm wider may be big.
Otherwise the design was good, does honami feel premium in the hand?
Posted: 2013-06-26 13:05:46
I didn't get to touch it, but it looked silvery to me. It's 5 inch btw.
Posted: 2013-06-26 13:07:38
20MP is a bit too much. Hope it goes down to 13 for the final release. Lower pixel density = higher dynamic range. Unless of course the sensor can pump out a pixel pitch in excess of 2 Microns with 20MP. Even then though, less MP means larger pixels and greater light sensitivity.
Xenon flash doesn't bother me too much. LED is far more useful, especially when not taking pictures. Unless there is a separate video light and LED, alongside the Xenon, I'd much rather stick with just plain old LED (or dual LED), much more versatile.
Posted: 2013-06-26 13:10:28
So nobody asked about the display...
How was it guys? comparable with togari? good colors/contrast/viewing angles etc?
The frame is also metallic or glass fiber polyamide a la Xperia Z?
thanks!
Posted: 2013-06-26 13:11:43
thanks!
It looked metallic.
Posted: 2013-06-26 13:13:36
