@unknownC151A
thanks for sharing info, So the front is very similar to the Z? I think I can picture it myself now
, are the sides also similar to Z with metal trims at the center side or is it a single material covering all the sides?
Posted: 2013-06-26 13:18:29
On 2013-06-26 13:18:29, reeflotz wrote:
@unknownC151A
Goto a Sony shop. The glass frame look like a Xperia V, the rest is a Z. I think it's metal.
Posted: 2013-06-26 13:21:55
C6903 is not honami
c6803 is not honami
c6903 is tablet z new version
c6803 is xperia z ultra ne version
c670x is honami (c6702,c6703,c6706,c6707 and c6733)
Posted: 2013-06-26 13:25:00
You mean it has bezels as big as the V and a speaker bar placed at the same position as the V's?
Xperia V[ This Message was edited by: JoJotaro on 2013-06-26 12:29 ]
Posted: 2013-06-26 13:25:56
On 2013-06-26 13:25:56, JoJotaro wrote:
You mean it has bezels as big as the V and a sound bar placed at the same position as the V's?
Xperia V
No. The speakers are at the bottom. And have long grills like the HTC One.
I must stress this a very early prototype, so early that the the a lot of the back design is wrap is plastic (the back). He refused to peel the plastic covering it though.
Posted: 2013-06-26 13:31:26
nodarsix - You and your fu***n numbers... Honami is Honami! Basta!
Get up your lazy ass and do something usefull instead waste the thread with your stupid questions...
When? Where? What? I DONT GIVE A F***!!!
Go help your mum in the kitchen... Seriously man, you need to relax.
[ This Message was edited by: king-james on 2013-06-26 12:38 ]
Posted: 2013-06-26 13:32:11
Unknownc151a: Hi! whats the prominent difference between the Z and Honami's front design? Is the sides straight cut like z or with angles like z ultra?
Posted: 2013-06-26 13:33:09
hopefully new ui is still in work...and able to catch up with honami release date...
Posted: 2013-06-26 13:40:32
add questiom unknown: Did they mentioned it will be the Honami or Z2?
Posted: 2013-06-26 13:40:48
What about the screen?
Posted: 2013-06-26 13:42:41
