General discussions : Non mobile discussion : want some MMS?
< Esato Forum Index > General discussions > Non mobile discussion > want some MMS? Bookmark topic
Page <  123 ... 121314 ... 104105106>
flaminglips Posts: 294
@super just rcvd a nowmms multimedia mms test does dis mean i cn now rcv mms msg...Stl cant send using nowmms it keeps promptng message failed vnknwn address...anway pls send it at 09172469190 tnx This post was posted from a Nokia 7650
Posted: 2003-01-09 22:47:00
Jison Posts: 356
Try me
+46705666166
Posted: 2003-01-10 08:59:00
superunknown Posts: > 500
Jison mms sent. Posted from a T68i
Posted: 2003-01-10 09:02:00
moongirl Posts: 21
Super-how can i activate d nowmms on my fne?do i have 2 log using my pc?thanks 4 d help! Posted from a T68i
rissa Posts: 0
is MMS free if you use the nowMMS settings on your phone?
.. i want same MMS too!
+639177922498
thanks!
@moongirl - just log-in to www.nowmms.com via pc and follow the instructions given... as easy as that! i hope this helps.
[ This Message was edited by: rissa on 2003-01-10 08:07 ]
Posted: 2003-01-10 09:04:00
moongirl Posts: 21
Thanks rissa! ;-) super-hir my numba globe!8982612 Posted from a T68i
Posted: 2003-01-10 09:13:00
Moongirl just visit and register at www.nowMMS.com send the settings over the air then you're ready to go.;-) flaming and others, MMS sent.;-) Posted from a T68i
Posted: 2003-01-10 09:15:00
Got it guys?;-) Posted from a T68i
Posted: 2003-01-10 09:18:00
moongirl Posts: 21
Posted: 2003-01-10 09:20:00
jcpsad Posts: > 500
ako din superunknown! +639178465648
Posted: 2003-01-10 09:22:00
