Page <  123 ... 121112121213 ... 184118421843>
xperia_aio Posts: 31
On 2013-06-27 20:03:07, litoni wrote:
whats with all the bashing guys? seriously.... its either take it or leave it, accept the fact that uni and i both have the photos, and stop asking about it cause we are not going to leak it.
we have technically seen the honami 360 degrees, except for the back.
the render is getting near, and like i said a billion times, just think of the Z with different build materials. 4mm taller and 2 mm wider than the Z
small info: the proto uni and i saw may most likely be the final product, hence the togari final product came out the same as the proto.
and like i said before, honami will most likely be called Z2. Im not going back few pages to quote what i said.
[ This Message was edited by: litoni on 2013-06-27 19:04 ]
hi.. can you describe the front of the phone? is it like the render you made with the NXT lights at the top n bottom.. or is it like the Z - identical design for the earpiece on top and mic at the bottom
Posted: 2013-06-27 20:45:03
Ambivalent_ Posts: > 500
@Unknown / litoni / and rest of you that saw Honami (i1); can you confirm dimensions that I got;
145x73x9mm
On 2013-06-27 20:01:05, warfareonly wrote:
Mini as in size mini or specs mini ?
Only in terms of screen size and resolution (4.3 inch / 720p). Rest of the specs should be identical, although I can't guarantee that It will have Honami's sensor being that smaller. It may or may not have it...
Posted: 2013-06-27 20:45:45
sponse Posts: 252
what about the notification light guys??
is it going to be like the zl ?
Posted: 2013-06-27 20:49:51
145x73x9mm
yes that sounds about right.. litoni said its about 4 mm longer.. 2 mm wider.. and maybe 1mm thicker..
[ This Message was edited by: xperia_aio on 2013-06-27 19:52 ]
Posted: 2013-06-27 20:51:05
sponse Posts: 252
so the 2 mm wider is going to be because of the diamond cut.. as in the togari case, so it is really built in nicely and wont be notice in front of a Z.
9mm which means we got a better battery from the Z and maybe the S800 take more space too? and obviously the 20mpx which is a much larger sensor than the 13mpx found on the Z.
Posted: 2013-06-27 20:55:37
MusaD.Dragon Posts: 226
Hmm the event in Paris in a week might reveal some stuffs
Posted: 2013-06-27 21:08:14
litoni Posts: 100
145x73x9mm
yes would be that, just that im not sure about the thickness but should be around that no thinner.
imagine, the cutting of togari's and the design of the Z, but thicker.
[ This Message was edited by: litoni on 2013-06-27 20:10 ]
Posted: 2013-06-27 21:08:30
from what i've seen of the design, i think it looks pretty damn sexy. the XZ is a gorgeous phone and if honami is an improvement on that, then there's no way it could be ugly.
Would be nice to know for sure if all the camera tech rumors were for honami or for another niche device. Though, if there are two devices then it would just make my decision that much more difficult hah
Posted: 2013-06-27 21:42:27
rss_ndrsn Posts: > 500
Wow, honami's dimension is disappointing! I really thought it would be similar to XPeria ZL. I am definitely not getting this device. Iphone 5s will get my money.
Posted: 2013-06-27 21:47:48
>>SAMEH Posts: 56
the new algorithm of processing image and noise-reduction by Sony.. is really promising!
improved JPEG production at 100% crop..
finally Sony manage to get ride of the blurry effect
[ This Message was edited by: >>SAMEH on 2013-06-27 21:02 ]
Posted: 2013-06-27 21:58:34
