Page <  123 ... 123312341235 ... 184118421843>
unknownC151A Posts: 459
On 2013-06-29 05:49:17, Felimenta97 wrote:
I've got an off question to you all: You're mostly located in Europe and Asia, as far as I can see... Most posts happens when I'm sleeping, as I'm on GMT -3 (Brazil).
[ This Message was edited by: Felimenta97 on 2013-06-29 04:49 ]
Well. Xperia phones are not very popular in North America.
Posted: 2013-06-29 05:57:32
On 2013-06-28 19:36:43, unknown13x wrote:
On 2013-06-28 16:02:40, randomuser wrote:
On 2013-06-28 16:02:00, vikeviki wrote:
can you answer my question
unknown13x already confirmed Interchangeable lens, S-Master is also most likely on board.
Don't misunderstand my word. What I heard isn't interchangable lens. It will be just add-on accessories. Probably something like this.
http://cdn.photojojo.net/stor[....]-a36c_600.0000001297643131.jpg
Yes that's what I meant too
Posted: 2013-06-29 06:15:13
Ricky D Posts: > 500
Sorry is there supposed to be a question in there?
Posted: 2013-06-29 06:20:32
Felimenta97 Posts: > 500
I've got an off question to you all: You're mostly located in Europe and Asia, as far as I can see, right? ... Most posts happens when I'm sleeping, as I'm on GMT -3 (Brazil).
Sorry haha. Should have made the post better. Anyway, check above.
Posted: 2013-06-29 06:33:48
vikeviki Posts: > 500
As unknown mentioned it will be 2 mm large than Xperia z,can we assume that place can be room for Xenon flash(mini),
so Sony might found a room for interchangeable lens and xenon flash?
Posted: 2013-06-29 06:56:24
reeflotz Posts: > 500
well I think as mentioned earlier, the c901 has a xenon flash + lens cover and is only 13mm thick, so without the lens cover I think it is possible to put xenon flash and still be able to maintain 10mm thickness.
The thing that seems impossible is cramming a 2/3 sensor on a 10mm thick body because I think the typical lens needed for that will be thick, not sure though.
[ This Message was edited by: reeflotz on 2013-06-29 08:36 ]
Posted: 2013-06-29 07:13:22
I found something interesting in Sony's site.
http://www.sonymobile.com/glo[....]ogle-android-41-jelly-bean.jpg
http://www.sonymobile.com/glo[....]ogle-android-42-jelly-bean.jpg
http://www.sonymobile.com/global-en/wp-content/themes/semc-main/img/android/google-android-43-jelly-bean.jpg
I believe all the OEMs were given Android 4.3 soruce codes already given how Android 4.3 leaked for the S4 Google edition. (Samsung in-charge of update for it).
[ This Message was edited by: unknownC151A on 2013-06-29 06:21 ]
Posted: 2013-06-29 07:18:25
The thing that seems impossible is cramming a 2/3 sensor on a 10mm thick body because I think the typical lense needed for that will be thick, not sure though.
[ This Message was edited by: reeflotz on 2013-06-29 06:16 ]
yes,not sure on 2/3 sensor that is the reason Sony might end up in 20mp camera or there is another variant with camera sensor,however on the leaked pics the phone thickness is little more.
so c15a android 4.3 is android 5.0
Posted: 2013-06-29 07:28:11
4.3 is still jelly bean
5.0 is key lime pie.
so 4.3 =/= 5.0
Posted: 2013-06-29 07:59:02
mzr7 Posts: 42
So I have a question
So far we know that the z will come on tmobile on july 17th right? So what people are pointing out that we will get a z2 on july 4... um does this make any marketing sense for anyone?
Just putting it out there. Something is not right only would make sense if t mobile gets the z2 not the z!
If it isn't the z2 on tmobile well then facepalm I would so like to know who handles their strategy for cellphone release/unveil
Posted: 2013-06-29 08:52:57
