On 2013-06-30 06:54:33, jianlin wrote:
no idea about that...maybe unknown from usa know about it...
5" 1080p Triluminos ,X-Reality, WhiteMagic, OptiContrast (IGZO?)
2GB RAM, MSM8974 2.3ghz
s master mobile, stylus support
2/3" Exmor RS with Sony G Lens and accessories ,4K recoding, SteadyShot, ISO up to 12800
IP58 dust water resistant, 3000mAh, 32 GB Internal, LTE
[ This Message was edited by: jianlin on 2013-06-30 05:59 ]
Awesome jianlin,true camera centric phone ,its a beast i would say
Thanks binling
Posted: 2013-06-30 07:02:40
2GB RAM, MSM8974 2.3ghz, 3000mah
20mp, 2/3" Exmor RS with Sony G Lens and accessories ,4K recoding, SteadyShot, ISO up to 12800
[ This Message was edited by: jianlin on 2013-06-30 06:01 ]
do you know how to open .so file?
maybe i can find more info in the .so files?
Posted: 2013-06-30 07:04:01
pretty cool if all these specs are absolutely true.
but often times, aren't there things in spec sheets or whatever they're called, that don't make it to the final product? for example.. they're just there to test possible things, but not taken out even when the device doesn't have the feature. *shrug*
I don't want to get my hopes up too much I guess. I just want to be wowed! August can't come soon enough
Posted: 2013-06-30 07:04:10
where did 32GB internal popup?
random wrote in 1st page...but 32gb seem unlikely for sony style...16gb more realistic...
Posted: 2013-06-30 07:04:23
Wow is the sensor 100% Confirmed ?
My only concern is the Sony battery. Its okay for Honami but not that good for ultra. Hoping for the said new battery technology from Sony
[ This Message was edited by: jeff17 on 2013-06-30 06:14 ]
Posted: 2013-06-30 07:05:24
no idea. You do not generally open .so files, they are usually stored in /lib or /user/lib and used by programs that reference library routines from within them. They are not programs per se but shared libraries of object code linked to specific programs at runtime ( like windows DLL's). They're dependencies of the programs that install them. Copied.
Posted: 2013-06-30 07:07:13
WhiteMagic + Triluminos?
are they using two different backlighting methods for this panel at the same time?
Posted: 2013-06-30 07:07:44
supercoolman Posts: > 500
thought the last summary was 16/32. 32 would be REALLY sweet if price will not "upgrade" with with the same ratio
objdump -p
Posted: 2013-06-30 07:08:38
as Ambivalent say honami screen is 700 nits...random say 500 nits...sound possible now with WhiteMagic...
Posted: 2013-06-30 07:12:16
firmware version will be something like this
14.1.G.1.263
ro.semc.product.model=C6906
ro.semc.ms_type_id=PM-0460-BV
ro.semc.version.fs=AMERICAS-LTE
ro.semc.product.name=C69
ro.semc.product.device=C69
ro.product.model=mmm45i7lmieuoiu
Posted: 2013-06-30 07:17:52
