Benling any chance of usb 3.0 drivers you found and also different memory option(card)
as 4k video cannot be transferred fast in usb2.0
[ This Message was edited by: vikeviki on 2013-06-30 06:29 ]
Posted: 2013-06-30 07:21:38
On 2013-06-30 07:12:16, jianlin wrote:
On 2013-06-30 07:07:44, MartenR wrote:
WhiteMagic + Triluminos?
are they using two different backlighting methods for this panel at the same time?
as Ambivalent say honami screen is 700 nits...random say 500 nits...sound possible now with WhiteMagic...
WhiteMagic Triluminos screams IMPOSSIBURU to be true, Perhaps it will be using Sony's new BlueMagic technology?
or maybe Blue Laser backlighting to achieve that luminance.
Posted: 2013-06-30 07:36:08
supercoolman Posts: > 500
Sony Magic
Posted: 2013-06-30 08:03:06
@BenLin
The dump you have, is it of the model C6906 or C6903 ?
Posted: 2013-06-30 08:07:42
On 2013-06-30 08:07:42, randomuser wrote:
@BenLin
post above writed c9606...america LTE version...
Posted: 2013-06-30 08:11:12
@BenLin
yes,C6906
Posted: 2013-06-30 08:13:12
When is honami event? :D
Posted: 2013-06-30 08:43:00
At my house
Posted: 2013-06-30 08:55:43
What did your sources say?
Posted: 2013-06-30 09:03:07
Just to summarize the info on i1 with latest inputs from BenLing, litoni, unknownC151A, aurelius.
5.0" TRILUMINOS display with X-Reality
Snapdragon 800 2.3 ghz
2 GB RAM
16/32GB Internal storage, microSD expansion (native 64GB sdxc support)
2/3" Camera sensor 20 MP Exmor R, Sony G Lens f2.0, upto 12800 ISO, 4K Video recording, LED/Xenon Flash
SteadyShot Feature, Add on Lenses
IP58 dust/water proof, shock resistance
Stylus Support
3000mAh battery
Glass Front, Metal body
2.2 MP Front facing Camera with 1080p Video capture, Exmor R
NFC One Touch, Wifi Miracast
Multiple sensors including Pedometer and Pressure sensor
Android 4.2.2/4.3
Updated UXP
IR Remote
Multiple Camera effects including Augmented Reality, TimeShift etc
BT 4.0
LTE
[ This Message was edited by: randomuser on 2013-06-30 08:41 ]
Posted: 2013-06-30 09:04:33
