Regional >
Europe, Middle East and Africa
> Thread For UK Users (archive)
worth a try..
Posted: 2003-02-21 18:05:00
yep got another 3mins to wait and then will give it a go
after installin the cd should i have file manager in sony ericsson/p800/ ? coz it aint there but im sure it should be!
Mornin.
Deize![ This Message was edited by: Eleventy7 on 2003-02-21 17:07 ]
Posted: 2003-02-21 18:06:00
no, file manager is a 3rd party prog..
Posted: 2003-02-21 18:14:00
yeah but it says there's a file manager included with the cd, am installin the update but its stuck at 51%, gonna have to cancel and do an uninstall. arse
Posted: 2003-02-21 18:15:00
Yeh thats the normal Filemanager. U can see it after installation in the start menu &/or desktop called 'My P800'
Posted: 2003-02-21 18:20:00
it dont bloody work, have uninstalled the cd vers and installed the updated vers from the website, still wont connect to the phone. getting a bastid error message when it tries to connect
Posted: 2003-02-21 18:49:00
apps > C panel > connections > cable >
Cablestatus: PC Connect
Posted: 2003-02-21 19:18:00
yeah thats what its set to
Posted: 2003-02-21 19:36:00
Have a look at this:
http://eephone.tripod.com/ What do you think?
Posted: 2003-02-21 19:38:00
erm isnt that off some old fone from years ago?
Posted: 2003-02-21 19:46:00
