Page <  123 ... 127012711272 ... 184118421843>
sponse Posts: 252
On 2013-06-30 18:10:52, cu015170 wrote:
On 2013-06-30 14:41:52, Shotokan81 wrote:
On 2013-06-30 11:51:47, sponse wrote:
For god sake people ! stop complaining about the lens's size!
Hi sponse, thanks for your reply. If you refer to my post, I did not complain, I asked a question as I did not know if this was possible.
yes it is possible that the sensor would be "that large" with that small lens !
look at the nokia eos lens ! it is the same size!
This answers my question perfectly, thank you for flagging this.
Its not.
You have to take into account the depth, not just the diameter..
lets look at that this way, the honami's 9mm is more than enough!
think of that the camera in the honami is posted on the corner ! so there is nothing behind it ! so the 9mm goes all for the sensor, while the eos and the 808 have the camera in the middle, where the screen is posted! so they need the bulky back to put the big ass sensor in the middle !
p.s. made a photoshop on how the back would actually look:
[ This Message was edited by: sponse on 2013-06-30 18:34 ]
Posted: 2013-06-30 19:07:12
@sponse.. can you add the side buttons and headphone jack as we know should be there? that'll give an all around image of what honami will very likely look
IM SO EXCITED!!
Posted: 2013-06-30 19:36:46
sponse Posts: 252
IM SO EXCITED!!
here you go:
[ This Message was edited by: sponse on 2013-06-30 19:41 ]
Posted: 2013-06-30 20:35:39
Felimenta97 Posts: > 500
Could you try to make a white version when possible? I want to have an idea on what it might look like...
But looks good overall.
[ This Message was edited by: Felimenta97 on 2013-06-30 19:45 ]
Posted: 2013-06-30 20:45:13
sponse Posts: 252
no because it's a lot of work already.. and i don't know how the bezel of the phone will be on the white version!
Posted: 2013-06-30 20:47:18
Ambivalent_ Posts: > 500
@sponse; I think we're close but what about the empty space that render has and prototype doesn't?
Posted: 2013-06-30 20:49:53
Ok, no problem Thanks for that last render also
Posted: 2013-06-30 20:49:54
@Guys that have seen Honami; can you help out please?
EDIT: It seems that both render and prototype have upper empty space but the prototype lacks bottom empty space.
[ This Message was edited by: Ambivalent_ on 2013-06-30 19:52 ]
Posted: 2013-06-30 20:50:36
Thanks SPONSE! looks great. i can feel it in my hands...
@ambivilent.. not sure what you're trying to say? Looks like the bottom bezels are the same to me.
[ This Message was edited by: moogoo on 2013-06-30 19:54 ]
Posted: 2013-06-30 20:53:29
It seems to me that render has some empty space (circled) while prototype has screen all the way to the edge of the bezel;
Posted: 2013-06-30 21:01:21
