Page <  123 ... 127112721273 ... 184118421843>
if you look closely and carefully, you can see the line of the screen. i'd point it out but i don't have any photo editing software to up the contrast to make it clearer. there is a bezel like in the render and it does not go to the edge of the phone.
[ This Message was edited by: moogoo on 2013-06-30 20:04 ]
Posted: 2013-06-30 21:03:49
Ambivalent_ Posts: > 500
I've just looked at the rest of leaked pictures and you might be right. It seems easier to spot screen/bezel gap in these pictures;
Posted: 2013-06-30 21:09:02
Felimenta97 Posts: > 500
I played with Contrast and Brightness a bit (first time ever) and came with this... VERY subtle but I think I can see it,a small line inside the red circle.
[ This Message was edited by: Felimenta97 on 2013-06-30 20:13 ]
Posted: 2013-06-30 21:12:47
stedus Posts: > 500
If you look closely, the bezel should be around this part
[ This Message was edited by: stedus on 2013-06-30 20:15 ]
Posted: 2013-06-30 21:14:38
litoni Posts: 100
the bezel is not that huge. I said it was 4mm taller which you take that by half, 2mm top and 2mm bottom. its a noticeable if you put Xperia Z side by side, but in reality its barely noticeable.
again with the sides, 2mm wider in total, therefore take that by half and 1mm wider on each side.
so
2mm
1mm 1mm
V
2mm
since honami is 5" screen also, the bezel may look huge compared to any other 5" smartphones offered atm. but youll get used to it and go meh"
[ This Message was edited by: litoni on 2013-06-30 20:24 ]
Posted: 2013-06-30 21:20:17
McKinley Posts: > 500
The frame is an instant win already for me.
It reminds me so much of Sony Ericsson P1i
Posted: 2013-06-30 22:37:18
smclion102 Posts: > 500
Oh ya good catch. P1i same frame and colour
Posted: 2013-06-30 23:05:06
smk582 Posts: 7
Hey everyone, my name is Steve. From the US. Been lurking for a while, but the new photos and renders pushed me over the edge to register. Awesome work guys.
Two things, one an observation, the other a wish:
1) I think that the blurry white square on the top right corner of the leaked photo might just be a plastic pull tab to remove the clear plastic screen
2) I REALLY hope the white version of the honami has an all black front rather than large white bezels on the top and bottom. I can't wait to find out.
Still keeping my fingers crossed for a xenon flash in the vertical hole to the right of the lens. Fingers crossed.
Posted: 2013-07-01 00:02:18
One of my sources sent me the specs of the camera (Thanks a lot!). He says the i1 phone (Honami) will have a selectable ISO range from 50-12,800 and it uses Super Steady Shot image stabilisation (2-3 stops). It also has an f/2.0 28mm equivalent lens. The sensor is a 20MP 2/3″ BSI Exmor R one using the same process as as the RX100mkII for superior low light performance. The phone will also have manual controls for shutter speed and some level of manual aperture control and it will have an all new Cyber-shot app which integrates with PlayMemories Online.
-http://www.sonyalpharumors.com/first-images-from-the-new-sony-i1-smartphone-cyberhsot/
Posted: 2013-07-01 00:03:23
that sounds AWESOME!!!
finally.. the pocket friendly camera that i'll always have with me and can take great photos!
Posted: 2013-07-01 00:23:39
