General discussions : Non mobile discussion : want some MMS?
< Esato Forum Index > General discussions > Non mobile discussion > want some MMS? Bookmark topic
Page <  123 ... 131415 ... 104105106>
superunknown Posts: > 500
MMS sent;-) Posted from a T68i
Posted: 2003-01-10 09:23:00
moongirl Posts: 21
Super-i cnt oper ur mms,network error!i tried 2 switch frm globe mms den gprs!it doesnt work?panu po yun?thanks!o kailangan maglog me sa now 2view ur mms? Posted from a T68i
Posted: 2003-01-10 09:29:00
Guys when you receive a read report. Just click yes so that I'll know if my MMS are read. Its free anyways. Posted from a T68i
Posted: 2003-01-10 09:30:00
Moon try changing the settings under MMS to connect using globe GPRS. Not MMS. Posted from a T68i
Posted: 2003-01-10 09:32:00
Moon i mean the wap profile under your MMS. Use globe GPRS not globe MMS.;-) Posted from a T68i
Posted: 2003-01-10 09:34:00
Jison Posts: 356
Worked great!
Thx
Will get NOW settings and try sending myself
Posted: 2003-01-10 09:37:00
Ph users, use nowglobeph as wapprofile under your MMS. It will work' . ;-)jison you. Re welcome mate! Posted from a T68i
Posted: 2003-01-10 09:45:00
Jison Posts: 356
I sent u Super
Let me know if u get it.
I don't have globe gprs. The one I got from NOW is "Now Euro SE"
Posted: 2003-01-10 09:51:00
moongirl Posts: 21
Huhuhuhu! Super i cnt open it! Bket ganun?ive tried sending ota 2 globe sa 2951 para bka sakali magng ok pero d padin. Kc last jan1 pa ko d maka open eh!panu na? Posted from a T68i
Posted: 2003-01-10 09:59:00
legallypogi Posts: 170
@*- pm me your # if u want tons of mms!:-) Posted from a T68i
Posted: 2003-01-10 10:09:00
