@Stook:
I think you are incorrect.
Honami lens can have a small diameter, the quantity of light that will reach the sensor does not depend on the lens diameter but of the ratio of the lens diameter and focal distance, or apperture.
If we are told that the apperture is F2, it does not matter whether the diameter is small, it means the focal distance is equally small so the right quantity of light corresponding to F2 reaches the sensor.
https://en.wikipedia.org/wiki/F-number
@Jojotaro:
For a given apperture, If we have a small lens diameter, it means we have a correspondingly small focal distance and then a wider angle of view. Angle of view depends on the focal distance according to the same link.
I do not think we need to worry about the diameter of the lens, if it has a F2 apperture and 1.7 micron pixel pitch, it will have one stop advantage over nokia 808.
Then it is a battle between Nokia pixel combining algo and sony BSI and noise reduction tech, but starting with a full stop advantage, it sounds difficult for Sony to lose the IQ battle.
Edit: talking about low light shots here, which what i am interested in
[ This Message was edited by: Shotokan81 on 2013-07-05 13:49 ]
Posted: 2013-07-05 14:46:06
If Honami can produce a decent looking iso3200 image at full res then it wins by a mile
but I don't think it would be as good as as RX100 at the same ISO setting.
Posted: 2013-07-05 14:53:11
NOKIA will present next week the next Lumia Flaggshipp! A cameramonsterbiest with 41MP resolution + Xenon light...
"The shipments of Nokia Lumia 1020 will hit the stores on July 22 and the smartphone is expected to go on sale in the first week of August."
So I think NOKIA win this battle vs Sony in best camera... Honami will have no chance...
And don't attack me! It's just my opinion...
[ This Message was edited by: king-james on 2013-07-05 13:57 ]
Posted: 2013-07-05 14:53:20
The cameraphone will be available few weeks later after announcement!!! That means August for sure! So I think NOKIA win this battle vs Sony in best camera... Honami will have no chance...
[ This Message was edited by: king-james on 2013-07-05 13:54 ]
Well in fairness, 41MP is useless on anything other than the main purpose of the phase 1 implementation which is oversampling, while daylight shots are great with pureview mode disabled, nightshots at full resolution are just as bad as tiny sensor smartphones could produce. and Honami is expected to outperform it pixel by pixel.
anyway aren't we talking about Sony rumors here?
[ This Message was edited by: razec on 2013-07-05 13:59 ]
Posted: 2013-07-05 14:57:46
Is this Rumour topic?,common guys ,few threads are simply their individual opinion,let this thread be Dead,if you want to talk on camera,create a new thread and talk.Lets wait for a week ,untill then be RIP
Posted: 2013-07-05 14:59:01
"Nokia Lumia 1020 to be priced at
$602, hit stores in August"
GSMArena
only 600!!!
[ This Message was edited by: ArsenalFan on 2013-07-05 14:03 ]
Posted: 2013-07-05 15:02:13
the camera topics being discussed in the previous post were related to Honami, so it's part of the rumors as far as objectivity is concerned, unless we only discuss about what will be the next xperia device and set aside the technical details surrounding it
Posted: 2013-07-05 15:03:36
No worries King James, we shall see.
I hope for Nokia they make an outstanding camera, because the EOS will be a camera centric phone while the Honami will be a phone with outstanding performance in all departments including camera.
Also with Microsoft windows for mobile phones 8, it is not like Nokia has any other selling point outside the camera.
However, I beleive Honami has the potential to be better than Nokia 808 in low light for the above reasons.
Ramu told us that Nokia EOS should be weaker than Nokia 808.
So we shall see
Posted: 2013-07-05 15:03:54
@Razec,
I am not pointing at you but to all,You have Apple in-front and talking on Orange doesn't make sense,Any how I am not going to comment,this thread is being more and more Off topic,good luck guys,thread is lackluster more.
Posted: 2013-07-05 15:13:29
@Shotokan81
lens size does matter. Even on DSLR the larger diameter lense matters. You can't force the light in - the small lens will create diffractions.
Don't know if its a right article but here is smth
http://www.luminous-landscape.com/tutorials/resolution.shtml
If we get the production unit the we will see (probably have to buy the new RX100 as well) but I have heard that right now the max ISO on Honami proto is 1600 and its not very usable.
Posted: 2013-07-05 15:17:33
