I´m confused
should i buy Honami or wait for Honamini?
Posted: 2013-07-14 13:59:23
On 2013-07-14 13:59:23, sami92a wrote:
I´m confused
wait for Hona
max
Posted: 2013-07-14 14:09:52
@Razec
Hi.
Something caught my attention in your post, there is a contradiction with the information we have for mouths.
Indeed, there is three possibilities :
- the equivalent focal length is 28mm and the sensor size is 2/3" (crop factor : 3.93), which leads us to a real focal length of 7.12mm (28/3.93) : that is what I thought to be reality and the best solution.
- the equivalent focal length is 28mm and the real focal length is 5mm (like you write in your post), which leads us to a crop factor of 5.6 and then a sensor size of 1/2.3" (crop factor of 5.64), the most common size for sensors of compact cameras : a very bad news because it is smaller than what we all expected.
- the sensor size is 2/3" and the real focal length is 5mm, which leads us to an equivalent focal length of 19.65mm : a very wide angle, definitely incoherent to integrate into a smartphone in which the angle of the lens is fixed...
Am I wrong? A big doubt settles suddenly...
[ This Message was edited by: hacker113 on 2013-07-14 13:21 ]
Posted: 2013-07-14 14:14:45
On 2013-07-14 14:14:45, hacker113 wrote:
@Razec
Hi.
- the equivalent lens is 28mm and the sensor size is 2/3" (crop factor : 3.93), which leads us to a real focal length of 7.12mm (28/3.93) : that is what I thought to be reality and the best solution.
- the equivalent lens is 28mm and the real focal length is 5mm (like you write in your post), which leads us to a crop factor of 5.6 and then a sensor size of 1/2.3" (crop factor of 5.64), the most common size for sensors of compact cameras : a very bad news because it is smaller than what we all expected.
Great observation, I honestly have no idea about the real sensor size so I didn't include it on the specs I've confirmed, and yes its 5mm based on the EXIF info I've extracted. if it translates to anything smaller than 2/3" then that's sad
but let's not rule out the possibility that it could be a mistake on the EXIF data or something else. I don't know myself, as I was merely retelling what the samples told me
[ This Message was edited by: razec on 2013-07-14 13:22 ]
Posted: 2013-07-14 14:22:01
I´m confused
wait for Hona
max
HonaMax??? hahaha
Posted: 2013-07-14 14:27:48
Ok.
Hope it's just a mistake.
Anyway thank you to report this information
Posted: 2013-07-14 14:33:38
The sensor size is 2/3". No doubt about that.
Posted: 2013-07-14 14:37:14
XperiaJunkie Posts: > 500
Don't know if I have missed a post on it but has therefore anything confirmed about the flash yet?
Posted: 2013-07-14 15:06:39
Hi I've been curious regarding the bezel of Honami and had a rough idea. Based on what litoni describe, Honami is 4mm taller than XZ and 2mm wider. Thus the dimension would be 143 x 73 x 7.9 mm.
(Above is Xperia C, dimension at 141.5 x 74.2 x 8.9 mm, 5 inch screen.) Could its bezel be that large? IMO the width 73 and 74 mm difference should feel similar in the hand.
Any thoughts on this?
On 2013-06-26 11:44:05, litoni wrote:
source: seen it with my own eyes.
Im not going to say much as I promised someone.
design wise: personal opinion: I am not impressed with the design if it is actually going to look like what I had saw.
dimension: 4mm taller than the Z, 2mm wider than the Z, thickness same as Z.
same magnetic dock thingy: seems like sony is going universal with that dock from now on, therefore no need to keep buying special made docks.
3.5 mm jack is on the top left (facing the front of the phone), no flaps covering it.
as spoken earlier by others, the bottom is indeed just speaker grills.
has a camera shutter key.
[ This Message was edited by: litoni on 2013-06-26 11:28 ]
Posted: 2013-07-14 15:08:45
If Honami's camera would be able to come close to 1020 it would be a great achievment considering it is around 5mm thinner around the camera.
Posted: 2013-07-14 15:11:22
