Page <  123 ... 148514861487 ... 184118421843>
XperiaCute Posts: 298
how about FFC tag + microUSB port ??
[ This Message was edited by: XperiaCute on 2013-08-05 21:30 ]
Posted: 2013-08-05 22:29:54
Xajel Posts: > 500
The device isn't big like Ultra, so the magnets should hold it even in that location I think... or it might be duo to weight balance ( top side might be heavier than bottom side ) or both reasons might be correct
Posted: 2013-08-05 22:31:31
there seems to be additional port that uncovered in plastic case .. !
[ This Message was edited by: XperiaCute on 2013-08-05 22:04 ]
Posted: 2013-08-05 23:01:24
smclion102 Posts: > 500
Yes thats possible magnetic port can be a little left side also.
Posted: 2013-08-05 23:35:23
On 2013-08-05 22:27:44, CrownedAkuma wrote:
@xdomino996
Are we sure the 2 is the IR blaster? I mean couldn't it work even if covered with thin rubber? what if it is the Xenon and we were all fooled by Sony into thinking that the Xenon was absent??
Curious why would IR need a opening Could it be Xenon? and also the IR opening behind is pretty big.
But the camera portion is also bigger i.e Camera + Flash? .
Posted: 2013-08-05 23:39:26
Dont forget Huiyi said the leaked prototype was pretty OLD.
Posted: 2013-08-05 23:43:10
Ambivalent_ Posts: > 500
Why wouldn't IR port have an opening? Won't the plastic cover block IR signal (or make it substantially weaker)?
I wouldn't have my hopes high on Xenon.
[ This Message was edited by: Ambivalent_ on 2013-08-05 23:31 ]
Posted: 2013-08-06 00:31:04
That hole is too small for a Xenon bulb to fit, and even if it really had a Xenon in it, it be too weak compared with those that have larger bulbs such as the old CS featurephones. I hope there'd be an accessory flash gun instead with its own battery and connects through NFC+Miracast.
Posted: 2013-08-06 02:54:58
the other side of Honami ..
4- microSD + magnetic dock
[ This Message was edited by: XperiaCute on 2013-08-06 02:28 ]
Posted: 2013-08-06 03:16:42
vivftp Posts: > 500
Wouldn't be the first time I've seen Sony make a case that didn't account for everything on a phone. One of my friends bought the ZL and the case from Sony and it had no cutout for the IR blaster. We tested it in case it was built to let the signal thought, but it never worked with that case on.
Under a month until Honami announcement! Can't wait!
Posted: 2013-08-06 04:23:21
