On 2013-08-08 08:40:49, bipinm wrote:
Looks same...The flap is also visible...
The front of the phone is facing top...
I was wrong before...
[ This Message was edited by: bipinm on 2013-08-08 07:45 ]
I don't understand how this pic is at all confusing! In the teaser pic, u can see the volume rocker to the left of the power button, and the flap to the right, EXACTLY like the leaked side profile pic. There can be no mistake about that! Therefore, the front of the phone is to the top of the image.
Posted: 2013-08-08 10:56:16
As mentioned above by FMW300 and also on xperia blog, it seems the device is posted screen up, with the back of the device on the bottom
http://www.xperiablog.net/201[....]teaser-for-sony-honami-leaked/
the power button like on previous xperias is pointing downwards, meaning the back of the device and this seems to be the case here with the top of the image the screen and the bottom being the back. So the purple might just be the glass on the front reflecting the light, or more likely a coloured bezel around the screen for either black, white or purple. Although I am probably wrong, will be interesting how the final design will look.
If anything, perhaps EVleaks will have a full press honami photo soon
Posted: 2013-08-08 11:21:16
^Yeah, xperiablog nailed it.
I think my ninja may be right with his guess, ramu.
1 - is obviously a flap covering ports or slots.
2 - is definitely the volume rocker
power button is on the same position, only the shutter button is in the dark at the teaser image and not visible.
[ This Message was edited by: DexterMoser on 2013-08-08 10:44 ]
Posted: 2013-08-08 11:21:28
thats what i was saying...i didnt drew lines..lol...
Posted: 2013-08-08 12:07:34
yes it must be the screen, but look in this picture, isnt that purple part of the frame?
Posted: 2013-08-08 12:08:12
u cannot see screen in this angle...Purple is definitely part of the side frame....
Seems like this is the final product...
Posted: 2013-08-08 12:10:31
Oops my bad
Posted: 2013-08-08 12:14:48
Damn you're right!
And this makes ramu partly correct
Posted: 2013-08-08 12:41:55
CrownedAkuma Posts: > 500
The wait si killing su all! We are craving for info like drug addicted dudes for their daily injection! We are in withdrawal!
I'm liking this so much!!!!
By the way! I'm expecting some surprises for the 9/4! I think that we have just seen older (if not oldest) prototype and Honami will wow us.!:)
Are there any rumours about the notification light in Honami? I would like so much something like the U or the SP (or even like the Miro or the M) Sony c'mon! It's a flagship phone! Put on it something that amazes, the Z only had a shirty single LED!!!
Posted: 2013-08-08 12:50:57
