The Camera looks promising
So we now have 2 devices to be announced 4th Sept
Honami
New Tablet
BTW, Will Xperia Tablet Z2 support stylus or will have the same tech as ZU and I want a remind of its XR5 specs again
Posted: 2013-08-12 13:07:22
@up
+ Honami Mini
Posted: 2013-08-12 13:12:28
No, honami mini/Ray 3 will not be shown at IFA.
Posted: 2013-08-12 13:19:58
ohh. iPhone comes out September 10, so Sony is late.
Posted: 2013-08-12 13:28:17
On 2013-08-12 12:32:01, razec wrote:
^^ I wasn't cropping, I was just showing some problems with the lens/post processing. like that noise that appears like a crisscross pattern.
That pattern noise is most likely just sensor noise. The smaller your pixel size the more you get of it. Without RAW output it's impossible to tell for sure, but I'm very confident this has nothing to do with the lens or post-processing and is just something you have to deal with when you're using these resolutions on a small scale.
Posted: 2013-08-12 13:29:17
hope honami had bezel like Xperia ZL
Posted: 2013-08-12 13:32:52
XperiaJunkie Posts: > 500
I will be royalty miffed if there is going to be a Tablet Z 2 launched at IFA. I got mine on launch day in the UK on the 22nd of May and a new one announced ONLY a few months later BAD FORM SONY.
Posted: 2013-08-12 13:41:03
Keep Dreamin
I think the only way to solve the big screen bezel is to make the phone thin Like ZU >>> that way the design will keep its legendary
Posted: 2013-08-12 13:47:05
I agree, that it has nothing to do with lens itself. Unless the lens can't resolve the amount of details and it needs more processing. Those artifacts look like icy crystals and I have to agree with what you said earlier that it is probably due to luminance noise reduction. It seems that sony wants to have smooth output with no grain.
We need RAW data for analysis!
Posted: 2013-08-12 14:38:54
If we're at a stage where we need RAW data and a pixel by pixel analysis to determine whether or not the quality is 'good', then surely we're at a stage where if you want better you should buy a quality camera i.e. does it matter that much on a phone?
Not aiming directly at the above post, but rather at the last few pages.
[ This Message was edited by: Ricky D on 2013-08-12 16:01 ]
Posted: 2013-08-12 16:59:14
