Yes Exmor R = back illuminated
I believe HHT - Handheld Twilight Mode is Honami's biggest combat weapon against L1020 in low light
[ This Message was edited by: randomuser on 2013-08-13 14:02 ]
Posted: 2013-08-13 15:00:40
HHT works by stacking 6 high ISO images and micro-aligning them as one less noisy and more detailed output, oh wait the presence of HHT means Honami can burst capture at least 6FPS!
Posted: 2013-08-13 15:08:04
XperiaJunkie Posts: > 500
Will the S-Master amp really make that much of a difference to the audio quality I own an Xperia Z along with the NFC capable headphone the BTN200
Posted: 2013-08-13 15:08:19
The difference is day and night
Posted: 2013-08-13 15:09:13
The S master chip on the old walkman X was absolutely fabulous, but we couldn't say much about Honami's, unless it's the same chip or even better I think It'll be much better than anything else in the market right now
Posted: 2013-08-13 15:11:32
Depends on the person/type of music. If you are an audio aficionado then yes it will be a notable difference (with the S800 integrated chip alone) Sony's own chip will make the difference greater.
But don't expect WONDERS though, it's not the same chip used in Walkman X/Z/F etc. Just a derivative of sorts.
With no new high end walkman being launched, there IS a possibility Sony might use the same S-Master MX chip from Walkman Z/F but from what I've heard that is not the case sadly. So let's keep our expectations low for the actual quality. Just better than Z and other phones, not on the same level as Walkman Z/F and Cowon players.
It won't do much for the loudspeakers, but i1 speakers should sound much better than the Z no doubt as there are 2 stereo speakers against 1 in case of Z.
[ This Message was edited by: randomuser on 2013-08-13 14:16 ]
Posted: 2013-08-13 15:11:41
I have an Xperia Z along with the Sony BTN200 NFC headphones and the audio quality is superb. My question is though will the S-Master amp in the Honami really make it sound that much better for an audiophile like myself and will it also work for the loudspeaker (the loudspeaker on the Z isnt the greatest)
Posted: 2013-08-13 15:12:15
let's hope the speaker of honami at least on par with htc one...
Posted: 2013-08-13 15:19:18
Thoughts on this ?
http://www.gottabemobile.com/[....]onamis-interchangeable-lenses/
Posted: 2013-08-13 15:22:05
No it won't because it's water resistance but atleast it will be better than the z by a lot
Posted: 2013-08-13 15:22:32
