On 2013-08-16 11:35:05, randomuser wrote:
It depends on the type of card. A class 10 UHS-1 memory card won't slow down your phone
Thanks, now can you please recommend some micro SD cards of that (10 UHS-1) standard? Are those official Sony's? I want to buy some extra memory for Honami from day 1.
Posted: 2013-08-16 11:45:23
@Romu
I wish Sony do not continue with
omini-balance design in 2014 ..
see who people was bashing Samsung when its made S4 = S3 Plus ..
[ This Message was edited by: XperiaCute on 2013-08-16 10:53 ]
Posted: 2013-08-16 11:48:55
@Ambi
Get this
http://www.sony.co.uk/product/sd-microsd-high-speed/sr32uya[ This Message was edited by: randomuser on 2013-08-16 10:55 ]
Posted: 2013-08-16 11:54:24
On 2013-08-16 11:48:55, XperiaCute wrote:
@Romu
Sony updates its design language annually, and its track record shows that, they have plenty of talented design engineers.
Posted: 2013-08-16 11:58:05
I most certainly will if Croatian Sony has it. Thanks again.
EDIT: got it!
http://www.sonycenter.hr/inde[....]=products.view&product_id=7627[ This Message was edited by: Ambivalent_ on 2013-08-16 11:41 ]
Posted: 2013-08-16 11:59:31
Not exactly SMC related but what the heck
http://www.sonyalpharumors.com/sr5-qx10-and-qx100-manual-leaks/
Posted: 2013-08-16 13:10:14
Here is the first leak of a part of the QX10 and QX100 manual:
1) Power Button
2) Microphone
3) Display Panel
: Indicates that the card is not inserted
: Indicates the remaining battery charge
4) Hook for belt
5) Tripod
6) Ring Control (DSC-QX100)
7) The power / charge / movie
Green: Power on
Orange: running charging
Red: running video
8 ) Zoom lever
9) shutter button
10) Multifunctional jack
11) RESET button
Dimensions (standard CIPA):
DSC-QX100: 62,5 mm × 62,5 mm × 55,5 mm (W / H / D)
DSC-QX10: 62,4 mm × 61,8 mm × 33,3 mm (W / H / D)
Weight (standard CIPA) (including battery pack NP-BN, “Memory Stick Micro”):
DSC-QX100: approx. 179 g
DSC-QX10: approx. 105 g
Power Supply: Rechargeable Battery Pack NP-BN, 3,6 In the
Power consumption (during shooting): 1.1 W
Reminder:
The QX100 has the same RX100MII sensor and Zeiss lens ($600 here on Amazon).
The QX10 has the same 1/2,3 inch 18 megapixel CMOS sensor and f/3,3-5.9 lens as the Sony WX150 ($400 on Amazon).
[ This Message was edited by: smclion102 on 2013-08-16 12:21 ]
Posted: 2013-08-16 13:20:10
On 2013-08-16 11:41:23, Away wrote:
On 2013-08-16 10:20:33, Tsepz_GP wrote:
On 2013-08-16 08:35:26, randomuser wrote:
Sony 2014 first half flagship (April 2014)
5.2" Trilumimos 1080p
Msm8984 2.3 ghz
Adreno 420
4 GB RAM
4K video capture
20 MP camera
3200mah battery
Whoomp! There it is.
The difference this time round is that the first half flagship will have leading, or at least matching specs at the same time as others. Remember the days we used to say Sony squeezes the most out of its hardware, so if it had up to date specs, it would wipe the competition away? Well, the time has come. Everyone could see it would because the Z was pretty much up there, but this even a hater like you could see.
Coupled with better compression, and hopefully larger rom, what else did we ask for?
One thing I asked for was one flagship year, but I suppose more options will never hurt as long as they are supported and marketed, and XB seems to have been spammed with update info these past few months, so I think they are supported, and the Z was marketed, so I really do think it's okay.
2 flagships a year still won't come close to emphasising one a year. I think one killer one after the s5 would have the best effect, but spamsung would soon release another it seems. No one cares about lg. They do about HTC, but they're the next Nokia.
[ This Message was edited by: Away on 2013-08-16 10:42 ]
Deja vu.
Yes, nobody cares for LG, explains why they are now the 3rd largest smartphone maker, 2nd largest Android OEM and 4th largest mobile phone maker, if nobody cares for them then not a single soul cares about Samsung, yeah? Just following that incredible logic of yours.
Could you please remind me where Sony stands again?
Posted: 2013-08-16 13:22:46
wow.Adreno 420 sounds awesome.I love you RAMU
Posted: 2013-08-16 13:23:58
I knew it from the start that those lenses won't come cheap
Posted: 2013-08-16 13:27:48
