now im excited!! come to think of it, i hope that this device isnt 720p.. i hope its the ZL1 and has a full 1080p screen.
and a comment on the video: can we PLEASE get a global shutter on these phones ASAP, in all honesty.. is it that hard?
[ This Message was edited by: my ninja on 2013-08-25 02:24 ]
Posted: 2013-08-25 03:01:36
If that is Honami Mini then holy macaroni!
For comparisons sake the iPhone 5 is 123.8 x 58.6 x 7.6mm. If Honami Mini is 117 x 59 x ?? mm then this proves only one thing... Sony are wizards! Especially if it is supposed to have a 4.3" display.
OTOH, all insiders seem to believe Honami Mini won't see the light of day until Q1 2014, so what're the chances of it being shown at IFA? The only way I can see then showing it is if they want to get it out there and not actually release it for 3-4 months.
Posted: 2013-08-25 03:26:43
I did not say Honami has those dimensions, it was pure speculation by me based on the image and the dimensions on the phone next to it... That's why I said: My Guess...
But, it is still smaller than the 119 x 66 mm from the Q10...
@my_ninja: I don't think it is ZL1... If it is, then there would be no space for logos, speakers, microphones or nothing else on the front for a 1080p screen... If it is the ZL1, but it just has a smaller screen (staying at 1080p screen res), it would have a PPI of 536!!!!
[ This Message was edited by: Felimenta97 on 2013-08-25 02:44 ]
Posted: 2013-08-25 03:39:57
Just ran some numbers and that Sony phone is approx 109.24mm tall and 57.88mm wide. That puts it as being considerably smaller than the 123.8 x 58.6mm iPhone 5. If it is Honami Mini then damn! Then again the phone could be quite thick to make up for its other relatively small dimensions.
Posted: 2013-08-25 03:59:36
supercoolman Posts: > 500
can someone make that more focused. I'm guessing we can use blackberry's shadow at bottom and its thickness to estimate this phone's thickness.
Posted: 2013-08-25 04:17:16
I don't guys But I think this phone has small bezels so it might pack 4.3 display
with DUAL SIM functionality
just guessing xD
Posted: 2013-08-25 04:24:13
If we're going by the shadows at the bottom of the phones then they're almost identical. The Blackberry is a bit harder to guage once you blow it up to full size, but give or take a single pixel they're the same. So I guess this phone is approx 10.4mm thick then.
If I weren't getting full size Honami and wanted the Mini variant then this wouldn't bother me at all. A phone either the same screen size or slightly larger than iPhone 5, FAR more powerful, a larger battery and possibly the same camera as full size Honami? That little added thickness would be quite acceptable.
Posted: 2013-08-25 04:25:00
That isn't a shadow at the bottom it's a result of the shakey image. The top and bottom bezels on this handset are going to be very small judging by the height x width in this picture, but that could be an optical illusion from the camera movement too.
@sami92a my original post that you were making a point against expressly stated different textures/materials on a flagship device.
[ This Message was edited by: Ricky D on 2013-08-25 03:28 ]
Posted: 2013-08-25 04:26:49
I don't think the bottom portions are camera movement. You can get an idea of where the duplicate images are from movement by using the Sony logo as a starting point. The duplicate portion is above the actual phone and there is no duplicate portion below the phone. That means it should be a shadow we're seeing there.
[ This Message was edited by: vivftp on 2013-08-25 03:39 ]
Posted: 2013-08-25 04:37:51
I'd normaly agree with you @vivftp, but we're looking at very dark black imposed on black and very black imposed on a light coloured table. The light coloured table shows through the very bottom portion of the lower positioned exposure simply because it's very light.
My logic is that looking at the two positions of the Sony logo, the top position is slightly fainter than the lower position. My theory predict the lower position's overflow at the bottom exhibit a darker ghost than at the top. If you look closely, the evidence supports my theory. My theory would also predict the ghosts be of the same displacement in x and y axis, evidence suggest true.
The final observation I'd make to rebuff the shadow theory is that to cast a shadow like that the light source would have to be from the top and slight right of the picture, the reflection in the screen of the blackberry and the light gradient on the table suggests if anything the light source is to the top left.
Myth busted.
Posted: 2013-08-25 04:51:35
