Some interesting daimintions analysis from Digi-wo inducting that the Screen size roughly
4.26" ≈ 4.3" inch
[ This Message was edited by: XperiaCute on 2013-08-25 12:18 ]
Posted: 2013-08-25 12:34:37
Pretty sure its a iphone killer/ Honami mini thats the only surprise.
Honami Large and Honami Mini announcement with few camera lense and other accessories.
Posted: 2013-08-25 12:43:06
On 2013-08-25 12:34:37, XperiaCute wrote:
Some interesting analysis the daimintions from Digi-wo inducting that the Screen size roughly 4.26" ≈ 4.3" inch
very poor analysis of the screen size. it's clear that the dimensions of the screen are smaller then the analysis presents. don't you see that? the bottom sony logo is the accurate one so you can't cut it with the top dimensions of the screen. this means that the top and bottom bezels will be larger then what is presented. come on, you have eyes.
it's clear as the sun in the sky.
seems like the screen will be a bit smaller then 4 inch, maybe 4 inch.
[ This Message was edited by: amirprog on 2013-08-25 12:22 ]
Posted: 2013-08-25 12:59:47
This device above is not Honami Mini/Ray3! The screen is max. 4" big. I think even smaller, between 3.5 - 3.8").
You can't put Ray3 specs in this tiny thing... It's smaller than a ARC (125 x 63 x 8.7 mm) ...
[ This Message was edited by: king-james on 2013-08-25 12:09 ]
Posted: 2013-08-25 13:06:25
@ amirprog
it's really accurate analysis, I tried to calculated myself the display size my self
1- you need to proximate the actual dimensions of the display ( lenght & width ) in mm .
2- the calculate the diagonal side by pythagoras theorem
3- then convert it form (mm) to ( m) → ( inches )
I myself end up with 0.11 meter which is roughly 4.33 inches ..
[ This Message was edited by: XperiaCute on 2013-08-25 12:43 ]
Posted: 2013-08-25 13:35:12
the screen dimensions don't look accurate to me when looking at the photo itself, but the answer in just in a few days.
so we'll see who's right.
[ This Message was edited by: amirprog on 2013-08-25 13:29 ]
Posted: 2013-08-25 14:27:56
I think they are using the wrong outline. It's obvious that there's some motion blur in this picture, may it because it's a fake or because he used his blurry cam is not relevant for that. But you can see there are two Sony logos on top. IMHO the upper is caused by the blur and the lower one is from the "strong" outline. Also, with extreme manipulation of the lighting of this picture, you can amplify the contrast of the screen's blueish black to the body's black.
So we're more at this:
But am I the only one who thinks it just looks like an XZ?
Posted: 2013-08-25 14:57:23
spot on. this is what i tried to explain to him, but my english is not the best, not like my native language anyway. your drawing is much more accurate although to me the dimensions are tiny bit smaller then what you draw. as i wrote, i mean the upper sony logo is the shadow of the lower sony logo so it's not accurate to draw a line on top of the real sony logo (the lower one) like he did. anyone should be able to notice that.
yes, it looks like mini xz. seems like natural evolution - mini version of xz - this is the honami mini imo. similarly to upcoming iphone 5c - mini iphone 5 probably.
[ This Message was edited by: amirprog on 2013-08-25 14:23 ]
Posted: 2013-08-25 15:11:56
w00t w00t! GSM Arena used my scaling of the mystery device
http://www.gsmarena.com/sony_[....]t_blackberry_q10-news-6640.php
Posted: 2013-08-25 15:21:01
xperia blog also copied ur picture...
Mic reminds me of Z...Z mini???
[ This Message was edited by: bipinm on 2013-08-25 14:35 ]
Posted: 2013-08-25 15:33:47
