Sorry Xell, but your calculations are wrong. I can say with 100% certainty that that is Honami.
There is a lot more plastic around the plug than you think, and with this kind of extrapolating you're getting significantly different results.
Posted: 2013-08-28 15:21:54
Page removed?
[ This Message was edited by: randomuser on 2013-08-28 14:32 ]
Posted: 2013-08-28 15:28:06
Yup and random told us about a mini flagship that will have the same specs as honami. Idk what you're trying to prove ambi
Posted: 2013-08-28 15:31:42
On 2013-08-28 15:28:06, randomuser wrote:
For the 100th time what you call Honami mini = Ray 3. Honamini and Ray 3 are not codenames or official names so that statement makes no sense.
What you call Honamini is what me and huiyi referred to as Ray 3.
[ This Message was edited by: randomuser on 2013-08-28 14:28 ]
Look, there's no reason for us to fight, let's contribute to this forum as much as we can. Having said that, my info is that Ray 3 is a separate device from Honamini. I may be wrong, but since some of my Honamini info turned out to be true, I also may be right.. I'm not here for pissing you off, I'll just post my info and take responsibility when I'm wrong (as well as when I'm right). Cheers!
Posted: 2013-08-28 15:32:20
[ This Message was edited by: smclion102 on 2013-08-28 14:35 ]
Posted: 2013-08-28 15:33:16
So what, Honami and Honami mini will be identical twins just smaller?
Posted: 2013-08-28 15:33:23
Once again, don't expect a handset smaller than Honami with the same specs (no Snapdragon 800, most likely no 20MP cam). There might be a smaller high-end phone, but it won't be Honami-high-end.
Those specs on Alpha Rumours came from PDA DB and were just wrong. (Which is why they were removed from the site.)
[ This Message was edited by: Ambroos on 2013-08-28 14:34 ]
Posted: 2013-08-28 15:33:51
Page removed?
Don't tell me SONY issued a gag order?!?!?!
Posted: 2013-08-28 15:34:17
@Ambi
I'm not trying to fight either buddy, and frankly I have no grudges against you whatsoever as we're all Sony fans at the end of the day and there is no point in fighting.
I'm just saying what you refer to as Honamini is what me and huiyi referred to as Ray 3. Just think about it. What did "Ray" signify? Flagship specs in a small screen size. There is no point calling a 4 inch mid range device as Ray 3.
[ This Message was edited by: randomuser on 2013-08-28 14:34 ]
Posted: 2013-08-28 15:34:29
Posted: 2013-08-28 15:35:01
