Oops, false alarm
Posted: 2013-08-28 15:38:53
About that "Honamini" photo you all went scientific about: I made a simple comparison with my Z:
http://imgur.com/a/2TxUI
As you can see it's simply the Honami. The volume and camera buttons could have revealed this too, they would be waaaay too small on a smaller device.
Posted: 2013-08-28 15:46:06
It looks much smaller than your Z
Look carefully
Posted: 2013-08-28 15:51:25
and honami is bigger than xperia z
Posted: 2013-08-28 15:52:35
Look carefully
no, it's not. his z is smaller, no need to be a scientist. you can see that because the usb cable head of the honami is smaller then his usb head. and if you do zoom in a bit on the honami pic (which will be accurate size of the usb head) then z will be slightly smaller. it is the honami.
[ This Message was edited by: amirprog on 2013-08-28 15:00 ]
Posted: 2013-08-28 15:54:03
Look carefully
Well then I might have needed to zoom just a little bit more but once again I am 100% sure this image is Honami. Look at the power button, volume rocker and distance to the camera key! (And the audio jack, and I can go on.)
Posted: 2013-08-28 15:54:39
Oh well
, looks like I got way too excited for my own good.
Posted: 2013-08-28 16:00:18
Esato can get dangerous sometimes. Specs mentioned here by 'trusted' sources are always better than what we get in the end. Most of it are wishlists.
Don't expect any revolutionary stuff. Don't expect a smaller phone with the same (or nearly the same) specs as Honami. They can't bend the laws of physics. If Sony could make the internals of Honami any smaller than they are you would have had a phone with less bezel.
And please don't jump to conclusions from specs leaked on one site. We know nearly nothing about any other phone than Honami. We know there are more phones on the way, but that's all. We don't know their display sizes, processors, camera modules, nothing.
So just wait it out and don't disappoint yourself, since that's all you're doing.
(A good rule: if it's not on XperiaBlog it's likely not true.)
[ This Message was edited by: Ambroos on 2013-08-28 15:08 ]
Posted: 2013-08-28 16:04:27
Now now, not this arguing again. May I remind you what you said about the lenses (please say no, there's way too many pages to go through)...
Everyone knows specs change, and to get over excited is foolish, that much is clear too. Hence, they are called rumours on a rumours thread.
Some are right more often than others. Some may be wrong more often, but will reveal a significantly larger amount of correct information. In the end, as long as we don't cry over lower specs, then it's okay. I didn't follow the 2011 thread, but I'm sure all this was made clear in the 2012 thread...
Remember knowing the Z specs by November? Certain insiders were calling them ludicrous then... Especially the processors... They were badly wrong. Contributors to XB aren't infallible.
[ This Message was edited by: Away on 2013-08-28 15:44 ]
Posted: 2013-08-28 16:42:05
From what we heard, Honami has same screen problem like SXZ. I hope this time it is just prototype problem. I want SXZU screen quality.
Posted: 2013-08-28 16:43:14
