CrownedAkuma Posts: > 500
OT
Speaking of design... what do you think of this??
Isn't it horrendous???
man I love the big N (alias Nintendo) and their devices too... even if their design is so so... but this... this is ugly and unpractical
Nintendo 2DS
OT END
Posted: 2013-08-28 22:20:18
Forum troubles due to "less than" symbol, mods please delete this and my previous post. Thank you.
[ This Message was edited by: Ambivalent_ on 2013-08-28 22:30 ]
Posted: 2013-08-28 22:21:31
On 2013-08-28 21:12:32, Geoffxx wrote:
On 2013-08-28 15:35:01, Ambroos wrote:
Once again, don't expect a handset smaller than Honami with the same specs (no Snapdragon 800, most likely no 20MP cam). There might be a smaller high-end phone, but it won't be Honami-high-end.
Those specs on Alpha Rumours came from PDA DB and were just wrong. (Which is why they were removed from the site.)
I am honestly having trouble figuring out what you base your ....opinion.... on, the only difference I see between the Z1 and a Mini version would be the screen and the battery being smaller - the device might even be a little thicker, now anyone that understands the tech will know why I'm saying this
The problem with forums like these is people give random opinions without actually explaining why they are saying what they are saying - smaller screen requires smaller battery - the camera and the CPU and GPU have nothing to do with it
I know exactly what I'm saying, thanks. I just mean that the Snapdragon 800 is by comparison a bigger SoC than usual and it requires quite some power while in use. A smaller display would help, but reducing the battery size with a Snapdragon 800 would lead to too little usage time under load. And well, a Snapdragon 800 has no use really, especially not for non-full-HD-phones. A Snapdragon 400 makes more sense. A Snapdragon 600 might work too, but they'd have to be careful.
Plus, a bigger device equals slightly better heat dispersion. When you're dealing with powerhouses like the 600 and the 800 that becomes important. There's a very good reason Samsung never used the Exynos 5 dual in smartphones.
Posted: 2013-08-28 23:21:38
On 2013-08-28 20:35:09, Vit wrote:
I hate being a troll, but the real troll here was a certain random user and its XR5-God-confirmed info regarding the Honami.
I told you it would be laughable!
Ramu was vastly more right than wrong. Don't be hattin! And Honami is by no means laughable.
@Ambroos, I may be wrong but I think there might be a below 5" phone with S800 in next 6 months.
@Ermac84; no S-Master dedicated audio chip. Honami will be using Qualcomm's solution for audio processing.
And a
MASSIVE THANK YOU to xell for resolving the posting issue!
[ This Message was edited by: Ambivalent_ on 2013-08-28 22:31 ]
Posted: 2013-08-28 23:27:10
Would Sony skip an Android 4.3 update for the Honami, post release, going straight for an Android 5.0 one? Is this likely?
Posted: 2013-08-28 23:34:27
No,
Posted: 2013-08-29 00:09:35
Yes
Posted: 2013-08-29 00:13:01
I see your point there! although in terms of power consumption doesn't the Snapdragon 800 have asynchronous clocks for all the cores? so if the phone did not require all the power it could downclock the cores as needed and use less power. While you are right that you don't need snapdragon 800 for non-full-hd phones these phones have hdmi out which would output in full hd which paired with PS controller would make them fantastic for gaming thus requiring the extra power of snapdragon 800 and why people would like to see such power even in a smaller phone!
in terms of size yes the SoC would be bigger but I really hope Sony do manage to put it in even if it means the phone ends up being a little thicker to accommodate it. Sure the Soc itself may not be thick itself some of the other things like battery could be moved around it!
these are just my opinions. but I would love to see a phone smaller than Honami with similar spec in terms of power and camera, and I really hope you are wrong regarding this and have not heard of this device as yet.
Posted: 2013-08-29 00:16:35
Yes
No.
Posted: 2013-08-29 00:17:12
Yes
Motivate that yes.. how would it be possible ? you mean keep Honami on 4.2.2 atleast a year and then update to 5.0?
Posted: 2013-08-29 00:19:00
