somebody didnt get the joke...
Posted: 2013-08-29 10:06:53
On 2013-08-29 08:53:33, nightwing369 wrote:
On 2013-08-29 00:19:00, sami92a wrote:
On 2013-08-29 00:13:01, motvikt wrote:
On 2013-08-28 23:34:27, nightwing369 wrote:
Would Sony skip an Android 4.3 update for the Honami, post release, going straight for an Android 5.0 one? Is this likely?
Yes
Motivate that yes.. how would it be possible ? you mean keep Honami on 4.2.2 atleast a year and then update to 5.0?
So many different, conflicting answers... The thing is that Sony/SE have been very slow with updates in the past and with the case of the X10, they skipped an update to Android 2.2, choosing instead to go straight to 2.3. Do you think they would take the same approach as before, in that case, for the Honami; going straight for an update, after the Honami's release, to Android 5.0?
Then, I think maybe.
Edit: Sorry if this was not clear, I meant maybe not.
I hope this helps.
[ This Message was edited by: Shotokan81 on 2013-08-29 09:18 ]
Posted: 2013-08-29 10:14:47
Yes
I hope this helps.
So they'll either release the Honami with 4.3, or update to it to that very soon after its release?
Posted: 2013-08-29 10:24:37
Yes
I hope this helps.
Maybe.
I guess what I am trying to say is, if this forum members do not have the answer, you don't need to post the question several times.
You may be more lucky by posting the question on other sites with a different public. I can suggest the comment sectio of Phone arena to begin with.
I hope this helps
Posted: 2013-08-29 10:40:31
Unknown13x, where art thou?
I guess you have the complete Z1 spec sheet with u by now
Posted: 2013-08-29 11:15:45
Image Stabilizer on = Auto ISO and HDR off.
The moment you change ISO or on HDR, image stabilizer will be off.
That guy called Sephirot wrote that on hardwarezone.com.sg
So would that mean optical or digital image stabilization or is it just because of his prototype version?
Unknown where are you
Posted: 2013-08-29 11:25:37
Oh! Sounds like software stabilisation no?
But I hope with f2 lens and up to 800 iso you can be fast enough in many situations not to need an extra or two stops from stabiliser?
Posted: 2013-08-29 11:31:16
please no... if there will be no optical stabilization I'll have to skip this phone, damn.
Posted: 2013-08-29 11:56:25
Don't bet on skipping 4.3 and going straight to 5.0. Update schedules have been very consistent and predictable from Sony. X10 was am exception because it was the first foray into new territory.
Honami will get 4.3 just like all the omnibalance Xperias and some of last year's will.
Posted: 2013-08-29 12:03:28
I'm sorry to tell you but I think that's right, it is almost certain that Honami won't have mechanical stabilization, otherwise the infos regarding its presence would've been leaked long time ago
Posted: 2013-08-29 12:35:58
