On 2013-08-29 12:35:58, razec wrote:
I'm sorry to tell you but I think that's right, it is almost certain that Honami won't have mechanical stabilization, otherwise the infos regarding its presence would've been leaked long time ago
Agreed.
We basically know full Honami specs for a full month now (minus the ROM storage variants, if any
Posted: 2013-08-29 12:42:30
On 2013-08-29 01:29:52, dr.W wrote:
On 2013-08-28 23:21:38, Ambroos wrote:
On 2013-08-28 21:12:32, Geoffxx wrote:
On 2013-08-28 15:35:01, Ambroos wrote:
Once again, don't expect a handset smaller than Honami with the same specs (no Snapdragon 800, most likely no 20MP cam). There might be a smaller high-end phone, but it won't be Honami-high-end.
Those specs on Alpha Rumours came from PDA DB and were just wrong. (Which is why they were removed from the site.)
I am honestly having trouble figuring out what you base your ....opinion.... on, the only difference I see between the Z1 and a Mini version would be the screen and the battery being smaller - the device might even be a little thicker, now anyone that understands the tech will know why I'm saying this
The problem with forums like these is people give random opinions without actually explaining why they are saying what they are saying - smaller screen requires smaller battery - the camera and the CPU and GPU have nothing to do with it
I know exactly what I'm saying, thanks. I just mean that the Snapdragon 800 is by comparison a bigger SoC than usual and it requires quite some power while in use. A smaller display would help, but reducing the battery size with a Snapdragon 800 would lead to too little usage time under load. And well, a Snapdragon 800 has no use really, especially not for non-full-HD-phones. A Snapdragon 400 makes more sense. A Snapdragon 600 might work too, but they'd have to be careful.
Plus, a bigger device equals slightly better heat dispersion. When you're dealing with powerhouses like the 600 and the 800 that becomes important. There's a very good reason Samsung never used the Exynos 5 dual in smartphones.
Actually, the SD800 is virtually as power efficient as the 600. So I don't see what the point of your argument is, or how it is you can make that claim with such authority when tests prove it is not so.
http://www.androidbeat.com/2013/07/benchmark-snapdragon-800/
Also, I have no idea what you're talking about when you say the 800 is bigger than usual. What is usual? Both the 800 and 600 are quadcore built on 28nm manufacturing. Making arbitrary statements, like "bigger than usual" is not a helpful starting point for a discussion.
So feel free to point out wich 4 inch phones use Snapdragon 600?
It seems like when it comes to Sony, anything is possible if you believe the fanboys, next you will tell me Sony will use Snapdragon 800 in a smart watch
Posted: 2013-08-29 13:22:30
This is the previous leaked photo,just make it clearer.
Posted: 2013-08-29 13:52:18
Epic fail by Sony, no Xenon, no OIS etc hardly worth awhile whacking a 20mp camera on it then.
Could be a massive flop.
Posted: 2013-08-29 14:14:53
Another Troll eh
Posted: 2013-08-29 14:21:53
I hope they can use contrasting colors for the frame and the bezels. The contrast makes the phone better-looking and creates the illusion of smaller bezels. The black one should have a white/silver frame while the white one a silver/black.
Posted: 2013-08-29 14:27:21
qft
Also no Blue-ray drive and no 4k Display....big disappointment
I hope the camera can handle low light very well and the camera app starts faster then it did on the XZ.
If so i definitely will buy this beautiful device.
Posted: 2013-08-29 14:31:04
Nice troll monkey......oops I meant northMONKEY
Posted: 2013-08-29 14:36:59
Xperia Z1 Model
Posted: 2013-08-29 14:44:04
On 2013-08-29 14:44:04, BenLing wrote:
Xperia Z1 Model
the screen looks much better here then in previous leaks. a beautiful design. better looking then the z imo.
[ This Message was edited by: amirprog on 2013-08-29 13:49 ]
Posted: 2013-08-29 14:48:32
