On 2013-09-03 17:13:22, randomuser wrote:
No
From Sony:
Sony’s original By Pixel Super Resolution technology assists Cyber-shot in zooming up to 10x* without decreasing pixel count, giving photos a crisp, high-resolution feel that is nearly identical to optical zoom. Cyber-shot first zooms optically to the maximum optical magnification, then employs By Pixel Super Resolution technology to enlarge the image an additional 2x, producing sharp, clear images despite the increased zoom ratio. And by combining this function with digital zoom, up to 20x zoom* can be achieved.
based on my experience with A58 on a certain Sony store here, Clea Image Zoom is just a little bit better than the standard digital zoom, 808/1020Pureview's zoom is on a whole different league
I wonder if that BIONZ chip is just an abstraction layer run by the S800 chip or a true dedicated HW ISP chip. nevertheless the output should be the same, just that the HW based one might have higher performance than just a software emulation
Posted: 2013-09-03 17:17:49
On 2013-09-03 17:17:31, MNX1024 wrote:
@unknownC151A
That sucks, was hoping to get better audio quality out of the Z1. Mind explaining the "Pluse LED flash", which I assume should be "Pulse LED flash"?
Just copied from the document I recieved.
They called it "Flash/Pulsed LED".
[ This Message was edited by: unknownC151A on 2013-09-03 16:22 ]
Posted: 2013-09-03 17:19:46
@randomuser
Thanks, sounds great
definitely looking forward to it.
@razec
Thanks for additional info mate
[ This Message was edited by: reeflotz on 2013-09-03 16:22 ]
Posted: 2013-09-03 17:20:38
Pulsed LED flash is nothing new, It's present on Xperia T as well as ZL
Posted: 2013-09-03 17:21:32
So is the flash better than the one on the Z?
Posted: 2013-09-03 17:25:50
Here's another interesting line:
"Indeed, independent testing has confirmed that Xperia Z1 provides the best overall image quality of all leading smartphones."
Posted: 2013-09-03 17:26:06
@randomuser
Thought it was something new since it had such a flashy name and don't recall ever hearing that name either.
@unknownC151A
Any info on what radio frequency being used on which model on that document?
Posted: 2013-09-03 17:27:22
Yes
Posted: 2013-09-03 17:27:37
On 2013-09-03 17:27:22, MNX1024 wrote:
@randomuser
@unknownC151A
Networks
UMTS HSPA+ 850 (Band V), 900 (Band VIII), 1700 (Band IV),
1900 (Band II), 2100 (Band I) MHz
GSM GPRS/EDGE 850, 900, 1800, 1900 MHz
LTE (Bands 1, 2, 3, 4, 5, 7, 8, 20)
Posted: 2013-09-03 17:28:08
Xperia Z1 Full Specs-
All credit goes to unknownC151A
2.2 ghz MSM8974 Snapdragon 800
5.0" Triluminos 1080p Screen with X-Reality for Mobile
16 GB Internal, microSD expansion (SDXC supported)
20.7 MP Exmor RS 1/2.3" sensor with F2.0 28mm equiv lens, BIONZ for Mobile, 3X Clear Image Zoom
2 GB RAM
3050mah typical 3000mah minimum battery
IP55/58 dust water resistant
144x74x8.5mm
170 grams
Colors - Black, White & Purple
Companion products - DSC-Qx10/QX100 lens cameras, Smart Imaging stand IPT-DS10M, tripod SPA-MK20M
[ This Message was edited by: randomuser on 2013-09-04 12:46 ]
Posted: 2013-09-03 17:29:07
