When is ZL1?)
[ This Message was edited by: mobisekim on 2013-09-08 12:58 ]
Posted: 2013-09-08 13:58:07
On 2013-09-08 12:16:00, nodarsixar wrote:
1. Wheni is honami mini event?
2.what is honami mini spec?
3. When is Z2 event?
4. When is Z2 spec?
1. Nobody knows.
2. Nobody knows.
3. Nobody knows.
4. Nobody knows.
That's about the state in terms of Sony Mobile rumours. We hardly know anything about Honami Mini (Itsuki), and we know nothing about anything else coming after that.
Posted: 2013-09-08 14:01:23
On 2013-09-08 11:43:47, jianlin wrote:
http://www.qualcomm.com/media[....]obile-rf-launches-worlds-first
another world 1st in note 3 after usb 3.0 port...
New Radio Power Management System, Uses 20% Less Power And 30% Less Heat Than Existing Tech
why sony u always step behind competitor...
[ This Message was edited by: jianlin on 2013-09-08 10:48 ]
Samsung has more money. Simple.
Posted: 2013-09-08 14:04:54
<div class="pquote">
</div>
no no no.........................................
honami mini = xperia amami
http://ameblo.jp/povtc/entry-11601976740.html
Dimensions: 58 x 109 x 7 millimetres
Software+Environment
Embedded_Operating+System: Google Android 4.2.2 Japanese
Browse devices running this OS
Microprocessor,-Chipset
CPU:Clock: 2150 MHz
CPU: Qualcomm Snapdragon 800 MSM8974
Browse devices based on this microprocessor
Memory,:Storage;capacity
RAM;capacity: 2 GiB
ROM+capacity: 14.9 GiB
Display
Display;Type: Supported
Display;Diagonal: 4.3 "
Display;Resolution: 720 x 1280
Video+out: 1920x1080 (1080p) resolution
Sound
Microphone(s): stereo
Loudspeaker(s): Supported
Audio_Output: 3.5mm
Cellular+Phone
Cellular-Networks: GSM850, GSM900, GSM1800, GSM1900, UMTS800 (B6), UMTS850 (B5), UMTS2100 (B1)
Cellular-Data:Links: GPRS, EDGE, UMTS, HSDPA, HSUPA, HSPA+
Call+Alert: 64 -chord melody
Vibrating-Alert: Supported
Speakerphone_: Supported
Secondary_Cellular+Phone
Dual:Cellular+Network+Operation: Dual standby
Secondary-Cellular-Networks: LTE2100 (B1), LTE1800 (B3), LTE800 (B19), LTE1500 (B21)
Secondary;Cellular+Data-Links: LTE, LTE-A
Control;Peripherals
Positioning-Device: Multi-touch screen
Primary-Keyboard: Not supported
Directional_Pad: Not supported
Scroll_Wheel: Not supported
Interfaces
Expansion-Slots: No information
USB: USB 2.0 host/client, 480Mbit/s, OTG 1.3
micro-USB
Bluetooth: Bluetooth 4.0
Wireless:LAN: 802.11a, 802.11b, 802.11g, 802.11n, 802.11ac
Infrared+Gate: No information
Multimedia;Telecommunication
Analog-Radio;Receiver: Not supported
Digital-Media;Broadcast+Tuner: No information
Satellite-Navigation
Built-in_GPS-module: Supported
Complementary-GPS_Services: Assisted GPS, Geotagging, Simultaneous GPS
Built-in+Digital;Camera
Main;Camera: 20.7 MP
Autofocus_(AF): Supported
Optical-Zoom: 1 x
Macro:Mode: Supported
Built-in-Flash: Supported
Secondary:Camera: 2.1 MP
Additional_Details
Built-in+accelerometer: Supported
Ingress+Protection;Level: IP57
Battery: built-in
Battery;Capacity: 2400 mAh
[ This Message was edited by: nodarsixar on 2013-09-08 13:41 ]
Posted: 2013-09-08 14:25:39
honami mini
Posted: 2013-09-08 14:39:09
I want nightwing back.
Posted: 2013-09-08 14:51:47
58 x 109 x 7 millimetres honamini
125.3 x 66.1 x 8.5 mm s2
128 x 64 x 10.6 mm XS
honamini 4.3 inch should be bezel less....
Posted: 2013-09-08 15:46:42
Maybe main reason to shut those moaning Honami's bezel mouse down?
what is perfect than bezel-less and super-slim profile accommodate with decent chipset and battery.
Anyway, it hard to believe if this kind of tech is ready for mass level production.
Posted: 2013-09-08 15:51:59
Is anyone planning on attending IFA still to check out the different devices or is still present at IFA? If so please message me.
[ This Message was edited by: ascariss on 2013-09-08 15:57 ]
Posted: 2013-09-08 16:53:56
On 2013-09-06 19:02:09, CrownedAkuma wrote:
Talking about Watches...
This is the attempt of Sammy to trail the Smartwatch (or the Pebble and so on...)
Simply Ugly
It's thick and not good looking... Battery duration 18-20 hours... while the smartwach takes you trough 3-4 days (thanks OLED)... it has a camera (this is actually a plus, even if the camera is bad from what it has been shown), it is IP55 (so it will not be able to take a dive, whereas SW2 is IP57), compatible only with Note 2 and 3 at launch, then with SG3 and 4 trough update, will not work with brand different from samsung... FAIL ?? and it will cost 299$, so 100$ more then the already pricey Smartwatch 2... I think they failed hard...
To be fair...
Also the SW2 is thick...
the measures are SW2 9mm-41mm-41mm
GG 11mm-39mm-57mm
[ This Message was edited by: CrownedAkuma on 2013-09-06 18:22 ]
definitely will get Smartwatch 2 when became available in my country and hopefully with Xperia Z1 as well ..
Posted: 2013-09-08 17:03:34
