That would be amazing if Sony were to make the 10" nexus tablet. Based on all the other rumors Samsung is supposedly making the 10" tablet. Only 8 more days to find out
Even the source link at gizmodo lists Samsung as the maker of the tablet. I think it was just a typo when gizmodo copied the story.
[ This Message was edited by: DACHA on 2012-10-21 16:59 ]
Posted: 2012-10-21 17:53:49
Woah !!! that's one great rumor. Hope it turns out true. A Sony Nexus tablet sounds AMAZING
Posted: 2012-10-21 17:57:35
Its samsung not sony
seems to be a typo guys
Posted: 2012-10-21 18:27:53
On 2012-10-21 17:39:31, tam wrote:
When it comes to bigger tabs, sources confirm Google's been working with Sony on a 10-incher that's currently going by the name "Codename Manta" and probably ultimately called the Nexus 10. Probably. It'll run Android 4.2 (Key Lime Pie) and rock a 2560×1600 pixel display, which could boast more pixels per inch than the iPad. Whether this tab will just be announced or actually show up at the event is still up for grabs.
source :
http://gizmodo.com/5953546/re[....]ppear-at-upcoming-google-event
I think that's a typo. Original link says it's Samsung (from The Next Web), didn't even mention about a Sony device. Also, one comment from Android Police's post days or weeks before (when Occam and Manta popped up) suggests the same but with a 16x9 resolution. He did sound convincing.
Sources:
http://thenextweb.com/google/[....]s-android-event-on-october-29/
http://www.androidpolice.com/[....]oth-motorola/#the-manta-tablet
(the comment from Anonymous)
Posted: 2012-10-21 18:30:14
@randomuser
is it worth waiting for the Q3-Q4 flagship??or is Odin/yuga the preferable choice??what do you suggest??
[ This Message was edited by: tapas123 on 2012-10-21 20:06 ]
Posted: 2012-10-21 20:58:46
Could odin look like this ?
[ This Message was edited by: DACHA on 2012-10-22 02:51 ]
Posted: 2012-10-22 03:51:19
Iphone-ish as this?
I bet my right arm...
Posted: 2012-10-22 03:55:02
I dont like the design. Hope this is not ture.
Posted: 2012-10-22 04:19:06
Sony should put the usb port at the bottom part, it will leave them more space for the other buttons
the XT has nice design but the buttons layout are odd =.=, especially the power and volume buttons
Putting the usb port on the botton, and leave the sim card tray and the micro sd card to the left and make the buttons to a better place
[ This Message was edited by: stedus on 2012-10-22 05:59 ]
Posted: 2012-10-22 05:56:23
I reckon that a Sony design would have squarer edges than the ones presented by that concept.
However, it does look nice, if a little iPhone-ish (which automatically makes it a no-go)
Posted: 2012-10-22 13:21:53
