Sony Ericsson / Sony : Software, Firmware and Drivers : k810i dead.only red light near IR blinks
Check connection type if it is set to USB.
Maybe you are trying to connect using COM port...
Posted: 2008-09-03 16:19:46
no..i selected the port as usb..
someone told me to use 2 and 5 keys to connect..would that be helpful
Posted: 2008-09-03 16:26:13
Try it... you lose nothing...
Posted: 2008-09-03 16:32:04
even kulankendi is not detecting..
tell me some other alternative please..
Posted: 2008-09-03 16:58:29
Try Setool... If it doesn't the best option is to send it to the nearest service center.
Posted: 2008-09-03 17:01:43
please tell me where to download setool
Posted: 2008-09-03 17:08:18
Try searching for setool2lite on
www.4shared.com
Posted: 2008-09-03 17:14:41
recharge ur battery...............
Posted: 2008-09-03 23:40:31
You can try letting the phone on charger for 1 hour at least, but, to be honest, I don't think that is the problem...
P.S. Give it a go, you won't lose anything to try.
Posted: 2008-09-03 23:44:11
On 2008-09-03 16:15:32, gouthamcec wrote:
19:37:03| XS++ v3.0 beta (Sinyar) Ready !
19:37:03| Executed on Microsoft Windows XP
19:37:15|
19:37:15| Attempting to open the interface...
19:37:15|
19:37:15| TURN OFF PHONE!
19:37:15| Hold 'C' button on phone and connect phone NOW.
19:37:15| You have 30 seconds...
19:37:15|
19:37:45| Error: Cannot open phone communication port
19:37:47| Disconnected... Unplug the phone
this is displayed...
my phone is not switching on...i think that is the problem
Have u tried to clean contacts of connection port with spirit? It might be dirty and gave poor conductance.
Posted: 2008-09-04 15:21:39
