Regional >
Asia Pacific
> SE India thread Reloaded!
the fields r empty.also the ip address r empty.
Posted: 2005-08-24 14:31:07
try inputing those values in check. If still doesn't work there's some dialling rules mentioned in a site.
here's another solution:
# Open the Control Panel. Click the Network and Internet Connections option, then choose Network Connections. Note If the Control Panel is in Classic View, double click the Network Connections icon.
# Right click your Dialup Connection and choose Properties.
# While you can enable Dialing Properties, we recommend that you UNCHECK "Use dialing rules" and type the entire number INCLUDING properties into the "Telephone Number:" field.
# Once you have corrected the number, click OK and try the dialup again.
Si hoc non legere potes tu asinus es.
Gendou(^-^)[ This Message was edited by: blu_6779 on 2005-08-24 13:33 ]
Posted: 2005-08-24 14:32:14
no...couple of bsnl guys came a week ago and gave the modem.today someone called me up and said this is my username and password....try connectiing.
Posted: 2005-08-24 14:33:38
check this site out thugs, got the same problem which you have.
http://broadbandforum.in/lofiversion/index.php/t1564.html
and this one:
http://broadbandforum.in/lofiversion/index.php/t1769.html
Gendou(^-^)[ This Message was edited by: blu_6779 on 2005-08-24 13:39 ]
Posted: 2005-08-24 14:34:59
wow...same problem as mine...but the diff is i have not yet connected to broadband.
hope it solvs my problem.
VALARE NANNI BLU
Posted: 2005-08-24 14:39:22
and another one, bit more detailed
http://broadbandforum.in/lofiversion/index.php/t1901.html
AND HERE'S THE DIRECTORY WITH ALL BSNL PROBLEMS
http://broadbandforum.in/lofiversion/index.php/f39.html
hope everything works out.
Gendou(^-^)[ This Message was edited by: blu_6779 on 2005-08-24 13:43 ]
Posted: 2005-08-24 14:41:47
nanni what?
Posted: 2005-08-24 14:45:14
i am online on BROADBAND!!!
i think their server was down.
MAN...GREAT SPEED.WOW!!!
@blu,the forum helped me a bit.thanks for the links.nanni
Posted: 2005-08-24 14:54:18
"valare nanni" means "thanks a lot" in mallu.
Posted: 2005-08-24 14:57:49
vallare santhosham
now i can go back to my torrents
Posted: 2005-08-24 15:00:58
