On 2013-01-04 06:36:20, vivftp wrote:
lol, anyone else think the power button from the new phones would make more sense as the shutter as it looks more like a shutter button from a normal camera? Either way I'm sure the ones they're using will be more than sufficient, just thinking out loud.
AhHa I agree, good idea. I gave up on my Acro S shutter button, ruins the image too often. Didn't have this problem with the Neo, least its good for underwater though!
Posted: 2013-01-04 06:54:00
Remember though that these phones will likely have shatterproof sheets over top the dragontrail glass too straight out of the box, so if you're worried about scratches, they will likely be more scratch prone than the dragontrail. That doesn't mean they'll scratch easily mind you.
Posted: 2013-01-04 06:54:24
Dacha, that chinese rumor is 100% fake I'm sure. Why ? Because there is no APQ8060 S4 Pro. APQ8060 is an S3 chipset with 1.7ghz dual core scorpion cores and Adreno 220. There is also an S4 APQ8060A (S4 PLUS) which is a krait 1.7ghz dual core with Adreno 225.
Posted: 2013-01-04 09:54:32
Guys for clarification
Dragon trail glass, Gorilla glass both use -
Mineral Glass with Shutter/scratch proof sheet on top.
The same which Sony has been using for years.. But they are just better at it..
Posted: 2013-01-04 10:03:44
Dragon trail glass, Gorilla glass both use - Mineral Glass with Shutter/scratch proof sheet on top.
I think gorilla glass is over rated and dragon tail is much better material after watching plenty of videos about Xperia active,go and acro.
Posted: 2013-01-04 12:12:16
If the rumoured pricing of Yuga is around £400 then it will fly off the shelves but I'm guessing it will probably cost a bit mroe than that.
Posted: 2013-01-04 12:48:18
Yuga will be expensive cause of premium glass material and Odin should be cheaper.
Posted: 2013-01-04 13:01:15
http://api.sonymobile.com/fil[....]android-smartphone-300x169.png
the link used to have the mini photo of Yuga, but its removed.
Posted: 2013-01-04 13:30:20
3 days 12 hours left !!!!
Posted: 2013-01-04 13:58:24
I can't wait to see what other stuff they have lined up too. I hope they have lots of gadgets with a big 'wow factor'.
Posted: 2013-01-04 14:51:48
