Eh.... I'm guy and most likely going with purple too
Way to unique!!
Posted: 2013-01-07 07:32:09
Way to unique!!
You could wear a dress too!! That would be unique!!!
Posted: 2013-01-07 07:36:06
Nope thanks
Posted: 2013-01-07 07:37:54
Black : it looks like the camera button
White : nope it looks like a speaker
Purple : Yeah it does look like a speaker...
After a 100% image size increase in Photoshop
Black : Some times it looks like a camera button, and some times it looks like a speaker
White : It's a speaker no doubt of this.
Purple : I'll stick with the speaker thing...
So I guess Dacha source might be correct to the sad fact that Yuga doesn't have a camera shutter key
Only few hours left to confirm this...
[ This Message was edited by: Xajel on 2013-01-07 06:44 ]
Posted: 2013-01-07 07:44:02
18 hours 14 mins
http://blog.sony.com/ces/
Posted: 2013-01-07 07:52:34
Tegra 4 device can load in 27 seconds while a Nexus 10 takes 50 seconds to load.
Link text...
exynos 5 cpu should b faster than a6x...this is bcuz google did not optimize nexus 10 well...i bet exynos 5450 will beats tegra 4....
[ This Message was edited by: jianlin on 2013-01-07 07:37 ]
Posted: 2013-01-07 08:35:40
I will wait examination detail from AnandTech before reach any conclusion
Posted: 2013-01-07 08:54:41
Tegra 4 has the proprietary 4+1 design which comes with less compatibility than a real big.LITTLE design introduced by ARM them selfs... plus it uses normal A15 core optimized for lwoer voltage and power for compatibility reasons, which still higher power usage than big.LITTLE concept propose...
the other problem is being an NV chip which means developers unfriendly...
a Quad A15 in a big.LITTLE design is much much better and has better compatibility, it will mean a quad core all the time + it works like a hybrid car... when full performance is wanted the petrol engine is working ( Quad A15 cores ), when there's no need for high-performance the electric engine will start then ( Quad A7 cores )...
the only benefit I see from Tegra 4 is short time to market compared to big.LITTLE solutions which will take some time...
the GPU part is fully customized in big.LITTLE, they can use any sort of GPU cores depending on the manufacturer... same goes for LTE modem...
Posted: 2013-01-07 09:03:23
Only Samsung may offer the big.LITTLE config this year, they can't set power hungry Quad-A15 (Exynos 5440) alone in single die. Only wonder that how many core will they put in I hope not four more of ARM-A5 core.
Is Tegra 4 already confirmed working on single chip solution, I see them announce Icera i500 soft modem as well. I hope it not separately installed chip.
Posted: 2013-01-07 09:14:04
As far as I know BIG.little phone won't be coming this year. And as of now seems the GS4 won't use quad Cortex A15 due to high heat and poor battery efficiency
Maybe by the end of the year we may see a power efficient 1 ghz or 800mhz quad Cortex A15. Just guessing.
[ This Message was edited by: randomuser on 2013-01-07 08:56 ]
Posted: 2013-01-07 09:55:40
