Sony Ericsson / Sony : Software, Firmware and Drivers : k810i dead.only red light near IR blinks
he hasnt even pressed the
connect button.
i think you should visit this thread:
Help: I cannot CONNECT my K810i on XS+ (any version).
if you succeed connecting the phone to xs++ try this:
On 2008-09-02 20:36:54, strizlow800 wrote:
Just use XS++ and put the EROM file as "Flash MAIN firmware" file... Hit FLASH button and you are done.
or
On 2008-09-02 12:27:27, duhhh wrote:
Attention, be careful! After the upgrade EROM `a through KulanKendi, CID may rise to 53!
1. Download:
KulanKendiClient
2. Run, checkbox note: EROM UPDATE.
3. Push Flash Phone
4. Clamped on the phone buttons 2 and 5 and connect it to cable.
5. After completion of the process, remove battery and try to turn on phone.
here's also a member that fixed his problem with KulanKendi:
On 2008-03-07 10:27:38, markmaslin wrote:
hi chaps
just thought i would let you know that i managed to get my phone working, it looks like it was the erom that was the problem, i tried to use the wotanserver tool but that didnt work so i used a tool from another website think it was called kulkendi, any ways here is the link to the information.
http://www.esato.com/board/viewtopic.php?topic=136077#post1833443
thanks again for all your help :0)
mark
use this
sory my englisch !
-first instal USBFlash Driver
http://www.kulankendi.com/index2.php?pStrona=download
-in KK Client please option "EROM Update" and Login:kulan and Password:kulan
-now pres "Flasch"
...good luck
[ This Message was edited by: markmaslin on 2008-03-07 09:29 ]
Posted: 2008-09-05 04:04:56
KK client is not free though. I don't know if it offers free EROM flashing though, but for MAIN and FS flashing you need to pay.
Posted: 2008-09-05 08:24:14
yes...2 days back when i installed usb flash drivers and tried to connect my phone with xs++ my computer displayed a message that a new hardware is found...but i didn't know what to do after that..
Posted: 2008-09-05 21:01:50
After that, you need to download this drivers:
http://www.4shared.com/file/4[....]emc_usb_flash_drivers.html?s=1
Extract them and when hardware wizard asks for driver, browse to then and let it install them. Then you can use XS++.
Posted: 2008-09-05 21:31:09
Don't need to use da vinci wotan or other clients... They are payable. Just use XS++ and put the EROM file as "Flash MAIN firmware" file... Hit FLASH button and you are done.
I did this but the Install New Hardware Wizard appeared. Do i need to install software on CD I got with phone onto PC before I start? If so I do not have the disc to hand, can I download it from somewhere?
Thanks,
darrkaye
Posted: 2008-09-10 19:14:09
try this
one
Posted: 2008-09-10 19:15:57
I need help!!
K800i won't turn on, got red flashing light near IR. Tried downloading USB Driver (previous post) as I don't have phone software but still doesn't work.
I've installed KKClient, SEUS etc.
Posted: 2008-09-10 23:33:21
darrkaye
You can try folowing:
1/Try to clean phone`s connector
2/download
SETool Lite 1.08
3/start it
4/push "Identify" button
5/hold together 2 and 5 on phone`s keypad,
not "C"
6/plug the cable and wait a few seconds...
Now SETool must recognize your phone...
Good luck!
[ This Message was edited by: Goldmen on 2008-09-10 23:04 ]
Posted: 2008-09-10 23:47:55
OK, SETool has recognized my phone. What do I do now?
Thanks,
darrkaye
Posted: 2008-09-11 00:09:52
darrkaye
As you wish...
You have two options:
1/Try to use phone without reflash - may be it will work...
2/Reflash it
But anyway if it work - don`t do anything!
Posted: 2008-09-11 00:18:10
