General
> Sony Ericsson 8.1MP C905 Discussion (Shiho)
On 2008-10-03 17:30:46, Bialynia wrote:
On 2008-10-03 17:21:08, maidenfan666 wrote:
ok 8Gb it is
Screw 8gb, the 16gb M2 is out!
c905 only supports up to 8gb m2 cards.
Posted: 2008-10-03 17:47:50
you re wrong,tobias...it supports up to 32 gb m2 cards,when they will be released...
Posted: 2008-10-03 17:50:33
As max_wedge has said around the forums, 32gb card will be supported... In fact the card will be supported as soon as it if formatted with FAT32 filesystem. Windows operating system can format FAT32 cards up to 32MB so to use bigger one like 64GB (science fiction atm)
we would have to format it using Linux for e.g. in order for it's filesystem to be FAT32...
So 8GB and 16GB cards won't be any problem for the C905.
Posted: 2008-10-03 18:07:34
okey, just read that at the homepage that it supports up to 8gb.
http://www.sonyericsson.com/c[....]neportfolio/specification/c905
Memory
- Phone memory 160MB*
- Memory Stick Micro™ (M2™) support (up to 8 GB)
[ This Message was edited by: tobias84 on 2008-10-03 17:36 ]
Posted: 2008-10-03 18:35:34
Well it says 4gb for K800 I think while it supports up to 8gb... There is no limitation until the filesystem which is formated the card with is FAT32.
And of course, bigger cards, the phone works solver once they fill up with data.
Posted: 2008-10-03 18:36:55
32MB? I think you meant 32GB.
No need to load Linux just to format a large memory card. Just open a Command prompt and use the FORMAT command! This command should be able to format volumes up to 254 GB (4,177,917 clusters * 64 KB). The maximum for a FAT32 file system is 8 TB (268,435,445 clusters * 32 KB) but the command doesn't allow this maximum .
Posted: 2008-10-03 18:56:23
Actually the specs for the k800i say it supports up to 2gb even though it supports 8gb (with some memory issues as times). C905 should have no problem with 16gb.
Posted: 2008-10-03 20:15:40
16 and 32GB stick are even out yet..
My K800 got 4GB, it works good..
Posted: 2008-10-03 20:50:40
C905 postponed to end of October according to SEMC
http://semcblog.com/2008/10/03/c905-postponed/
Posted: 2008-10-03 20:55:48
Based on a screenshot from the Official Site? That means all phones with stars are 'postponed' then. What a load of rubbish!
are always messing with that site. Here's a picture of it today:
It's been released according to today's screenshot. If it has been postponed, I'd like a bit more proof than 'cause it's got coming soon written under it.'
Posted: 2008-10-03 21:14:52
