> Sony Xperia Rumors 2015
I hope they'll go with matte metal and black color option. Not whole black. If the new FCC device is the flagship phablet (not a midranger) Sony will have my money on September. Simply great.
Posted: 2015-07-21 20:02:53
The dimensions can't be for the entire device, still needs a top and bottom bezel, so that could be another 1 cm at the top and 1 cm at the bottom. As I mentioned before, size wise, we could be looking at something like this.
http://www.gsmarena.com/huawei_mediapad_x2-7075.php
Posted: 2015-07-21 20:10:52
@ascariss
Yeah, nobody here can deny that possibility but how do you explain this?
http://gadgets.ndtv.com/mobil[....]fcc-report-442729?site=classic
for z ultra the fcc measurements are for the whole device. did fcc changed they way of measurements since then? we would like to think not.
Posted: 2015-07-21 20:19:12
The pdfs are not filed by the FCC I believe, but instead by the Sony employees and unlike in the ZU docs, the new device's measurements could be just the display's dimensions and not the entire device. You mentioned it yourself after drawing it out, the diagonal and side dimensions do fit together, and the margins are super thin all around, top, bottom and sides, so no place for an front facing camera or sensors. We'll have to wait and see what this evolves into.
Posted: 2015-07-21 20:36:51
@ascariss
Yeah, they write in the pdf "display screen" but after thinking about it again, there is a possibility that it is a loose term for noting that it is a drawing of the front side and not of the display size only. anyway, like you said, lets wait and see.
Posted: 2015-07-21 20:44:37
These docs are standard. So believe me it is smaller than Z Ultra
Another one for M2 Aqua.
http://www.xperiablog.net/201[....]ccording-to-sonys-own-website/
It should be 182.42 mm instead of 178 if those are display sizes. (Right Triangle)
So here is the engineering. Shave off ~4 mm from the width (frames) and shave off ~30 mm (top and bottom bezels combined) do the right triangle formula a squared + b squared = c squared you get something around 6.25 inches for the screen size. (Helloooo Z3X
)This does sound logical. You even get the 16:9 ratio.
Display screen on those files mean it is the front of the device, the screen is positioned there. Anyways we'll see.
[ This Message was edited by: thetube on 2015-07-21 21:58 ]
Posted: 2015-07-21 22:13:26
Sony Xperia S60 & S70 Xperia: New top smartphones before the IFA?
http://translate.google.com/t[....]%2Fnews%2C88115.html&sandbox=1
Posted: 2015-07-22 00:00:13
S60 = 6" ??? and S70 = 7" ??? both should be available on 18th August. If true announcement should take place in one or two weeks. Probably before Samsung announces the Note 5 in mid August. S40? (compact) and S50? ("Z5") will than be announced at IFA.
[ This Message was edited by: JohnnyNr.5 on 2015-07-21 23:25 ]
Posted: 2015-07-22 00:24:02
i calculated with pixels , ratio is almost same ,so this device can be sony lavender.
http://data.en.yibada.com/dat[....]/34707/sony-lavender.jpg?w=685
high end sony s70 and s60 in 20 days from now? prices are too high to me.i wonder if they have special features...
i guess sony will show new models in august , but i'm not sure about their prices are higher then even z series.
[ This Message was edited by: blackzeros on 2015-07-21 23:32 ]
Posted: 2015-07-22 00:25:04
Qualcomm may sack 4000 employees, spin off its chipset-making operation
No surprise that they cannot get anything right.
Posted: 2015-07-22 03:35:34
