On 2013-01-09 22:43:15, sami92a wrote:
with good build quality there is no screaking and sounds in the plastics etc and there is no loose parts
U didn't get my post but its all good, never mind.
Thinking of waiting on a white magic screen too. I'm not willing to lower my brightness an even at a lil over 50% it just eats my battery. Viewing angles I have no problem with how they r currently.
Posted: 2013-01-10 02:17:46
for me it wasn´t White magic that made me like it but it was the small size and great specs
Posted: 2013-01-10 03:43:29
C3602
Android Ice Cream Sandwich
Qualcomm MSM8960 Snapdraogn
1.5GHz Dual-Core Krait
HD(720*1280)
1GB RAM
C430x
Android Jelly Bean
1.5GHz Quad-Core Krait
4.0"HD(720*1280) White Magic
8MP camera
1.5GB RAM
64GB ROM
2100mAh
If C430x already has a 4" screen, and assuming that the first number does indicate the size magnitude of the screen, then C3602 would have a smaller screen but is also HD?
I hope that the only rumor here that won't come true is that C3602 (hopefully they won't cancel this one) would be released with ICS, that's just wrong.
Posted: 2013-01-10 03:49:42
Guys, C430X doesn't exist. I made it up for Phonearena.
Posted: 2013-01-10 04:01:28
U have P? Lol how do u feel about white magic then. Random made it seem slightly overrated.
Posted: 2013-01-10 04:13:10
So, DACHA got a wrong info?
Posted: 2013-01-10 05:01:47
The problem with Samsung octacore is it's not an octacore... sure you have 8 cores but you actually have 4+4, same goes for Tegra 4+1, you can't say I have 5 cores... the fact that you can't run all the cores together to have a real octacores, you only have access to 4 cores at a time... ARM didn't mention any thing about balanced work distribution something like what is exist in multicore x86 CPU from AMD and Intel where different cores will run at different clocks depending on the work load that each core will have like you set an MP4 encoder to use 4 cores and let the other 4 cores work for your gaming...
On 2013-01-09 19:03:36, Felimenta97 wrote:
So, I'm curious. Which rumours that we had for Xperia Z didn't came true. I can remember only of White Magic and 2800 Battery. Anything else?
Also, any problem if I mention on my blog (teendroid.com) about the 6 inch pablet (only that is being developed) and the H2 flagship (only that it is an improved mix of Z and ZL)?
32GB Internal... White Magic wasn't that much expected as other spec. only some wishes and then confirmed and not confirmed so I wasn't counting on it...
[ This Message was edited by: Xajel on 2013-01-10 05:36 ]
Posted: 2013-01-10 06:23:53
they didnt bring S Master...Did they???
Posted: 2013-01-10 06:57:21
Afraid it doesn't seem like it
None of the specs I've seen have mentioned it.
Posted: 2013-01-10 07:01:20
but i love the earphones....Sound quality will be way better than before...
white paper says Z has
3D Surround Sound (VPT)
Bluetooth™ stereo (A2DP)
ClearAudio+
Clear bass
Clear Phase™
Clear stereo
Dynamic normalizer
WALKMAN application
xLoud™ Experience
Will it have Google now...???
[ This Message was edited by: bipinm on 2013-01-10 06:25 ]
Posted: 2013-01-10 07:23:22
