Sony Ericsson / Sony : Software, Firmware and Drivers : W810 Firmware Details and Bugs
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > W810 Firmware Details and Bugs Bookmark topic
Page <  123 ... 373839 ... 666768>
jepherberich Posts: 473
PM'd you
[ This Message was edited by: axilom on 2006-08-28 08:54 ]
Posted: 2006-08-28 09:38:15
miguel82 Posts: 414
Thank you BUFFBOY . But i´m wondering... why i would have to flash the phone and change CDA ... The update service should work with all unbranded phones! why work in some phones and not anothers? ... or is this another stupid bug ? =//
Posted: 2006-08-28 12:19:17
MattyGB Posts: 70
Oh no!! I tried installing 005 again on SEUS and it seemed to revert back to a previous screen very quickyl, while it was updating the software, and now my W810i is completely dead!
It won't switch on at all!
I tried installing the software again, but SEUS just said that "No Update is Available" and didn't give me the option to "Continue Anyway"!
What can I do??
Posted: 2006-08-29 02:18:12
MattyGB Posts: 70
Tried reinstalling SEUS, restarting computer and re-updating the phone but SEUS still just says there's no update available, with no option of installing it anyway.
What can I do? What is wantonserver? Tried Googling it but get no results.
Phone is still completely dead! HELP!
Posted: 2006-08-29 02:31:15
ashburyfaith Posts: 6
MattyGB. have the same problem, my fone won't start after using SEUS.
It's wotanserver not wantonserver.
http://www.wotanserver.com/
Posted: 2006-08-29 03:18:15
slugworth Posts: 400
no problems with the w810i here
Posted: 2006-08-29 03:29:35
MattyGB Posts: 70
Thanks for that Ashbury.
I've downloaded wotan and am going to try it out in a minute.
Will it re-install the sotware with Orange software as I had before, or a generic version.
Also, will trying to rescue my phone with this program invalidate my warranty?
Posted: 2006-08-29 03:34:27
MattyGB Posts: 70
Oh well, I can't get Wotan to work...
On my PC laptop, it won't recognise my phone. I think there's a problem with the Flash Drivers I installed, as, when I plug in the phone, holding down 'C', the PC tells me there is a problem with this USB device and that it's not recognised by Windozzze. Nothing I do seems to be able to reinstall the Flash Driver so the PC will see it.
On my Mac, running Virtual PC (which I used SEUS on), the Wotan Client won't run and just reports an error.
Looks like I'm stuck with a dead phone then and will have to get Orange to fix it!
Posted: 2006-08-29 04:48:06
Spindizzy Posts: 216
I have an issue with my phone rearranging appoinments that are set in the calendar. I've noticed that if something may have been scheduled for say Monday at 9:00am I might find it moved to a totally different day on a different month and with the new time now always saying ALL DAY.
My phone is software version CX1250316, firmware R4CK003 purchased directly from SE via the internet in the US.
Posted: 2006-08-29 05:59:54
abbafan1972 Posts: > 500
Well i tried to update on the SEUS it picked up my phone ok and said "updating software do not touch the phone", when the green bars had gone all the way to the end, it just stuck like that for about half an hour. In the end I just disconnected the phone.
It doesn't seem to have suffered any ill affects and seems to be showing latest firmware (R4DB005). I have checked and don't have the contact picture bug or the led light bug. A bit slow getting into view pictures in the gallery, but otherwise no problems.
Posted: 2006-08-29 09:13:24
