Sony Ericsson / Sony : Software, Firmware and Drivers : FAR plugin for internal file system access using DCU-60!
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > FAR plugin for internal file system access using DCU-60! Bookmark topic
Page <  123 ... 373839 ... 114115116>
max_wedge Posts: > 500
On 2006-06-18 19:23:55, Viper6787 wrote:
Guy's I need some help, I can browse phone files on my phone with FAR but whenever I edit a file and save or delete a file I will disconnect then do a settings reset and the file is still the same, the edits have gone or file comes back.
Any help apreciated.
You only need to do a master reset for someo files such as customise.xml
menu.ml, camdriver changes, menu icons, etc take effect with out a master reset. Infact when you do a master reset you will nuke the original content back over the new stuff, so don't do a master reset unless editing customize.xml
Posted: 2006-06-18 19:45:41
marcrp Posts: 5
Which maaster reset you have to do after editing cutomize.xml? Reset Settings or Reset All?
Posted: 2006-06-18 19:57:02
Viper6787 Posts: 4
Ok thanks, I deleted the camerashutter and focus sound then quit then did a settings reset yet the sound remains?.
Posted: 2006-06-18 19:57:58
hellogoodbye Posts: 85
can anyone help me which CDA I must write in customize.xml and how plz help when I start the phone this message apears
"Configuration error.Please contact your network operatoror service centre "
plz help me plz plz plz
Posted: 2006-06-18 20:39:05
and one more thing when i'am putting files in tpa/preset/custom it goes to drm plz plz help me
Posted: 2006-06-18 20:45:08
alexl22 Posts: 123
Anybody knows where's located the "Error" sound into the phone?? I'm looking forward to change it for a less disturbing sound...
Posted: 2006-06-18 23:33:58
dinho666 Posts: 103
hellogoodbye
you must delete the files in drm folder
then, delete the drm folder.
Copy every file back to the custom folder then create the drm again.
finalize the far, wait few seconds and turn on your phone... it will work...
i had the same trouble when i flashed my phone!!!!
Posted: 2006-06-19 00:20:57
Ja99iE Posts: 406
@alexl22
Its: /FS/tpa/preset/system/sound/failure.mid
Posted: 2006-06-19 01:18:27
rockygali Posts: > 500
so frankly... how do i go to this folder where i can edit my cam version?
"dopey dopey dope!"
Posted: 2006-06-19 03:54:12
You only need to do a master reset for some files such as customise.xml.
Don't do a settings reset - it will copy the files back. use far to delete the sound, then go into phone and test shutter sound - it should be silent. No reset is necessary.
Only if using customize.xml to silence shutter (suppress-camera) should you do a master reset or settings reset (btw both resets are a master reset - but one is settings only). But if you are only deleting the sound files themselves, don't do ANY kind of reset and it should work.
Get free themes from my themes site
[ This Message was edited by: max_wedge on 2006-06-19 03:15 ]
Posted: 2006-06-19 04:11:25
