Regional : Asia Pacific : S.E. Service Solutions Corner (ph)
< Esato Forum Index > Regional > Asia Pacific > S.E. Service Solutions Corner (ph) Bookmark topic
Page <  123 ... 373839 ... 939495>
kapitan jackal Posts: > 500
@*salamat uli ladies
seriously speaking, bumilis talaga R310 ko. next time mag TSAA na lang kyo
Posted: 2003-01-28 08:32:00
vctor Posts: 70
question lang po:
bakit kaya ganito behavior ng t68i ko?
meron syang default na gprs connection when i bought it tpos pag nag GO t68i ako nadadownload naman sya ang problema after ilang minutes bumabalik sya sa dating settings???
do i have to upgrade my SW i think its RB...something nde ko matandaan e gamit kasi ng wife ko...
Posted: 2003-01-28 14:27:00
@vctor, kung R1B sw mo, i suggest pa upgrade ka na SW
Posted: 2003-01-28 15:57:00
Erwin777 Posts: 226
Is der anyone here wu knows wer 2 download d standard mms template? Nag master reset k kya nawala lahat This message was posted from a T68i
Posted: 2003-01-29 08:01:00
crowing Posts: 475
@erwin777: I think you can find that in wap ng sonyericsson.com. im not sure if that's the one your looking for pero give it a try.
Posted: 2003-01-29 08:06:00
mackieboy Posts: 26
how much is the damage if i will replace my lunar gray case and its corresponding keypad to the mineral gray w/ keypad? my phone has SEMICON warranty 'til 2-11-03. do you have stocks of them? thanks.
Posted: 2003-01-29 08:21:00
vctor Posts: 70
@jackal
R2B025 tong sw ko...do i need to go and upgrade? parang nakakabother ksi yung behavior nya e
Posted: 2003-01-29 11:07:00
@vctor, pards pa-upgrade ka na. most probably BUG yan have it checked muna b4 upgrade pag nasa service point ka na
Posted: 2003-01-29 11:19:00
Erwin777 Posts: 226
hello ppol, wat can u say about re:automatic restart ng phone, may solution pa ba dun?
Posted: 2003-01-29 17:10:00
Rashkae Posts: > 500
Never encountered it
Posted: 2003-01-30 03:31:00
