Symbian phones
> TomTom for P990i
Thanks a lot for all your efforts to help me out. I have done everything that you mention, and when I remove the USB-cable, TomTom starts with the installation. It's now when the strange part begin.
When I press Install for TTN6, the installation bar shows for 1 second and then closes. Nothing is installed. Also, TomTom wants to install every time I pull out the USB-cable, after I had it connected to Fast File transfer mode.
See what files and folders I have on my Media memory below:
These files are in total 112 files and 17 folders. 19, 3 MB (20 259 060 bytes)
So I suppose I do everything right, but it won't install. Anyone that have had the same problem as me?
[ This Message was edited by: flizzy on 2006-11-22 08:27 ]
[ This Message was edited by: flizzy on 2006-11-22 08:28 ]
Posted: 2006-11-22 09:15:33
@flizzy
Are you using the UIQ version of Navigator 6 ???
Posted: 2006-11-22 22:39:00
Sure, I'm using tomtom_uiq3_6.020
Posted: 2006-11-22 23:53:58
That was about the only thing that I could think of, but that is the same as what I have running. Unless you have an old version of firmware that has issues ???
Posted: 2006-11-23 01:13:27
Guys, anyone got a link that works for the tomtom uiq download & great britain maps, none on this thread work for me.
Posted: 2006-11-23 03:12:37
Works great on my P990, but after restart or when card is removed and replaced, TT ask for new registration - little bit annoying- does anybody know how to fix it up??
Posted: 2006-11-23 11:14:55
@patchy: my site man, beta.johnex.se.
Have no gb maps though, not on the site anyway, they are to big....:S
[ This Message was edited by: Johnex on 2006-11-23 10:18 ]
Posted: 2006-11-23 11:17:44
@ skicraft:
My phone details are:
Phone
CXC162037 R9C001
Bluetooth
CXC162058 R3A01
Organiser
CXC162088 R1B01
CDA
CDA162014/1 R1B01
_________________________________
It seems like a lot of people have this number for CDA:
CDA162017/8 R1A08
Do I have a newer or older firmware for CDA? What is CDA anyhow?
What do you get if you upgrade the firmware today?
Posted: 2006-11-23 15:53:30
flizzy,
I think you need to update your phone !
Posted: 2006-11-23 17:21:34
I tried an upgrade but it says I already have the latest firmware.
Posted: 2006-11-23 18:15:47
