General
> Official K810i and K818 Discussion - (Samantha)
The RSS feeder isn't updating here either, and im still on the R1KG001 f/w.
*j
Posted: 2007-06-21 09:56:02
On 2007-06-21 09:31:00, aremaboy wrote:
Have you tried Setting- Allow Connection-Any Network?
Yes mate. Tried that as well.
I've emailed
about the problem and will post their reply as soon as I get one.
Posted: 2007-06-21 11:55:40
have you guys check the control for RSS in the phone. my RSS uppdates perfect and works perfect. (have not uppdate my firmware....gone do that on monday (DPY flash).
Posted: 2007-06-21 13:04:18
Could it be because of branded K810i firmware?
Posted: 2007-06-21 14:40:00
Mine's unbranded and not working.
*j
Posted: 2007-06-21 16:17:52
Hm, weird. No problems, as I said, with my R1KG001 K800i. It has the same firmware platform as K810i, doesn't it?
Posted: 2007-06-21 16:52:00
Mines got no branding either. Still no reply from SE yet.
This message was posted from a K810i
Posted: 2007-06-21 22:01:13
A member here with his R6BC002 K810i has no problems at all with RSS readers. Could it be due to network-dependence?
Posted: 2007-06-22 00:35:00
My K800 and my Z710 is fine. I use the same sim card in those as I use in my K810.
All internet settings, RSS settings in all 3 phones are the same as well. Just the K810 I'm having a problem with.
Oh. Found yet another problem. Seems a problem entering text on the web browser.
After typing out your message in the text box/window and you select OK. Theres only the first 2 words shown. Got back into the the text box/window and again, only the first 2 words are shown.
I have tried this when sending a PM on Esato earlier and also using MSN live messenger beta through the K810's web browser and get the exact same result.
Posted: 2007-06-22 01:44:18
so can anyone confirm that after updating their K810i,
the only probs they had was on RSS feeds not updating?
i mean, is that the worse scenario? so can others update now?!
:: EDIT ::
ei! got my new K810i.... is the lens cover not that firm as K800? its a little shaky if you ask me
[ This Message was edited by: rockygali on 2007-06-22 06:05 ]
Posted: 2007-06-22 03:47:24
