Sony Ericsson / Sony : Software, Firmware and Drivers : The flashing/modding thread - All phones - Patching for db2020 available!
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > The flashing/modding thread - All phones - Patching for db2020 available! Bookmark topic
Page <  123 ... 363738
kumaraswami Posts: 6
hai..
i hav a question ....i hav W200i wid firm ware R4gb001 CID 52
when flashing ,it asks for MAIN and FS and Cust files .....
i dont know about these files ...i mean ...which main and fs files do i need to download for my phone ...otherwise which(main and fs ) files fit for my phone ...
thanks in advance..
Posted: 2008-02-08 06:31:42
DeKosta Posts: 291
Hey, i have R8 K810 FW on my K800 right now, if i flash to R8 K800 firmware i do have to apply quick acess patch again - right?
Posted: 2008-02-09 16:29:23
hi ppl....is there any way to get W200i 's (R4GB001 CID 52 ) main and fs files and custom pack....i require file names also......
any one plzzz replyyy
Posted: 2008-02-11 09:18:21
limzm Posts: 65
yes of cause.
Posted: 2008-02-11 14:33:03
prasannads Posts: 8
On 2007-07-26 20:15:08, Xen0nflash wrote:
Free firmwares and custpack:
1. Download Wotanclient
2. Press start and connect your phone.
3. Choose which firmware and custpack you want and then press continue
4. It will download now and when finished it will say that your account doesn't have any credit.
5. Open the folder flash and you will find it there
Go to http://k550-to-w610.blogspot.com/
You will find a better tutorial
Posted: 2008-03-09 07:55:00
prasannads Posts: 8
On 2007-07-25 19:57:29, Xen0nflash wrote:
How to make your K800/K790 louder
Make sure that the battery is fully charged and remove your SIM card
1. Download Phonexs++ 1.5
2. Download W850 or W880 accustic
3. When you have extracted Phonexs++ you will have a folder named files to upload
4. Make a new folder in it called /ifs/settings/acoustic/
5. Put your accustic there
6. In phonexs++ press FSX then start FSX.
7. Disconnect and insert your sim card
8. Finished!
AT YOUR OWN RISK
How to make your K550/w610 Tutorial
Posted: 2008-03-09 08:00:12
khairie Posts: 3
can anyone tell me which camdriver and acoustic driver is the best for K770i?
Posted: 2008-08-16 11:49:52
mugaguest Posts: 21
Can my WOW ll acoustics that i got for my k750 work in a w850 or will there be complications because i just want to change the back and earphone acoustics???
Posted: 2008-11-13 18:44:31
no. the k750 uses apf and the w850 uses zapf.
Posted: 2008-11-13 18:54:49
mugaguest Posts: 21
Ok so what's the best acoustics to get the w850 with a loud backspeaker and earphone?
Posted: 2008-11-13 19:26:41
