Sony Ericsson / Sony : Software, Firmware and Drivers : K800 Menu Modding has begun!
one way is to use the K800 version of menuedit (available on se-nse) and use printscreen, or simply to take a macro photo of the phone's screen. They are the simplest methods. I think with some software (that requires service cable) it's possible to do screenshots, and possibly a java program, but I myself have never seen such software myself only heard about it.
Posted: 2007-10-06 03:19:06
@max
thanks for the prompt reply i will try the options you mentioned and upload my menu later tonight
tonchy
Posted: 2007-10-06 03:31:27
i have some problem trying to move time and date in layout.xml, cause there are two couple of Cartesian coordinates (x1,X2 and Y1,Y2). I try move date and time changing value but i can't understand why X1, X2 and not just X!
In fact sometime Time is too low sometime is too high on the display....
hope someone will help me
thanks a lot
Posted: 2007-10-09 17:20:16
thanks a lot
Its a square! Not a line! got it?
you have to define 4 spots
<!-- Text fields (x1, x2, y1, y2) -->
<attr value="16"/> <!-- Nbr text fields -->
<attr value="1"/> <attr value="239"/> <attr value="5"/> <attr value="-10"/> <attr value="10"/> <!-- 0 -->
<attr value="1"/> <attr value="239"/> <attr value="34"/> <attr value="56"/> <attr value="10"/> <!-- 1 -->
<attr value="1"/> <attr value="239"/> <attr value="34"/> <attr value="80"/> <attr value="10"/> <!-- 2 -->
<attr value="1"/> <attr value="239"/> <attr value="55"/> <attr value="80"/> <attr value="10"/> <!-- 3 -->
<attr value="1"/> <attr value="239"/> <attr value="82"/> <attr value="104"/> <attr value="0"/> <!-- 4 -->
<attr value="4"/> <attr value="236"/> <attr value="34"/> <attr value="184"/> <attr value="4"/> <!-- Notes 5 -->
<attr value="4"/> <attr value="236"/> <attr value="58"/> <attr value="184"/> <attr value="4"/> <!-- Notes 6 -->
<attr value="4"/> <attr value="236"/> <attr value="82"/> <attr value="184"/> <attr value="4"/> <!-- Notes 7 -->
<attr value="4"/> <attr value="236"/> <attr value="106"/> <attr value="184"/> <attr value="4"/> <!-- Notes 8 -->
<attr value="0"/> <attr value="173"/> <attr value="205"/> <attr value="281"/> <attr value="0"/> <!-- L 12h time -->
<attr value="0"/> <attr value="240"/> <attr value="181"/> <attr value="281"/> <attr value="0"/> <!-- L 24h time -->
<attr value="103"/> <attr value="236"/> <attr value="210"/> <attr value="234"/> <attr value="5"/> <!-- Time -->
<attr value="121"/> <attr value="236"/> <attr value="238"/> <attr value="262"/> <attr value="5"/> <!-- Date -->
<attr value="4"/> <attr value="99"/> <attr value="210"/> <attr value="234"/> <attr value="5"/> <!-- Timer -->
<attr value="4"/> <attr value="116"/> <attr value="238"/> <attr value="262"/> <attr value="5"/> <!-- Alarm -->
<attr value="174"/> <attr value="240"/> <attr value="211"/> <attr value="251"/> <attr value="0"/> <!-- L 12h time AM/PM -->
</attributes>
here's an example to remove operator name
[ This Message was edited by: pedrops on 2007-10-10 04:06 ]
Posted: 2007-10-10 05:02:11
thanks a lot
X1 means where it starts & X2 is where it finishes.
Same with Y1 & Y2. Thats the best i could explain it.
Posted: 2007-10-10 05:20:57
so its like a polygon shape where talking about here...
a box area where the fonts should appear... so then, what if thta box area is small for the whole fonts to show...
hence the phone wont show it... am i right?! which brings me to the question:
what is the standard box area for these fonts. like how wide or how thick the box will be... few differences in X2 from X1 (Y2 from Y1)?
[ This Message was edited by: rockygali on 2007-10-10 05:47 ]
Posted: 2007-10-10 06:45:09
it's all clear now.....thanks a lot
Posted: 2007-10-10 11:38:27
who's got the psp menu in german?
Posted: 2007-10-11 01:44:09
Can't you translate it?
Posted: 2007-10-12 04:19:44
don't know how to modify it:|
Posted: 2007-10-15 00:20:22
